Armilite
Rated 33kw = 44.25373hp at 8750rpms if it can be converted easy. Maybe run at a little lower rpms. Use's Ceramic Apex Seals. Don't know, if it use's the High Temp O-Rings the Mazda guys use. But this looks like and awesome small motor. Max rpms is 11,000rpms!
Follow us on FACEBOOK and TWITTER
Type : 4-stroke single rotor rotary engine | Dual Inlet with vacuum control | Onboard starter |
Power : 33 kW at 8750 rpm | Float carburettor with air filter | External starter |
Weight : ca. 17 kg | Clutch with 11T sprocket and cover | Ceramic apex seals |
Torque : 39 Nm at 7500 rpm | 3-piece exhaust with manifold and springs | 10T-, 12T- and 13T-sprocket |
Chamber Vol : 294 ccm | Standard engine mounts (�32mm x 92mm) | Chassis-specific engine mounts |
Max RPM : 11000 rpm | Ignition with start support | Metal clutch friction discs |
Ignition : PVL Fire 650 | 50W alternator | Dell'Orto carburettor VHSH30W |
Clutch : 2-disc dry centrifugal clutch | ||
Drive : �in chain type 428 |
