Lycoming IO-540 Cylinder Head Template
HomeBuilt101
Oct 20, 2015
384
Aguila AZ
I need to build an engine cooling air baffle for my airplane. The only realistic way to do this would be to use an aluminum sheet of metal that is attached to the engine heads using the same holes as the rocker covers. In other words this aluminum plate would be sandwiched between the cylinder heads and the rocker covers and two sets of gaskets would be needed to mount this on the engine
Does anybody have a template or a digital scan of this so that I could have it CNC cut locally
