cklskypilot
Hi to all. I am going to build a all wood air plane. it is a look a like of the fairchild 22 parasol wing plane. I also am going to build a set of wings that will copy a over all design of the t-craft wing. but will use a full ribs and flarerons also use a extended leading edge and incorperate full slats. the wing tips will a drop down type and will be made of foom and glass and will also work as a stol and float tip for a anfib. anfib to be built later down the road. as for now I am working on the 22. I hope to build it light and have a take off roll of less then 300 feet. I have look over the 701 and it jumps off the ground with in 100 feet. would like input on the wing design of the 701 and any thoughts about the wing that I am going to build. Like I said any input good or bad. THANK YOU. Chuck
