Crash rate ?
Discussion in 'Hangar Flying' started by Speedboat100, Aug 15, 2019.
  1. Aug 18, 2019 #81
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,390
    246
    Sydney
    Adding to above...
    Area rule is more about getting aero efficiency by drag reduction and thus reducing the apparent area of flat plate drag of a aircraft design.
    It has very little to do with the side area of the fuselage, eppenage or tail except the height of the tail. Thus not related to the volume of the rear.
    Conflating area rule to flying characteristics is not relevant.
  2. Aug 18, 2019 #82
    6,414
    1,665
    There seems to be more than usual Dunning-Krugers recently. I'm getting better at putting such people on ignore. Sadly, that is spoiling HBA for those are really are here to learn than to look smart.
    Never argue with a idiot, they will drag you down to their level, then beat you with experience.
  3. Aug 18, 2019 #83
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    Yes Inverse Pressure Gradient Matching. I recall reading it here..was it Norman ?
  4. Aug 18, 2019 #84
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    I agree 100%.
  5. Aug 18, 2019 #85
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    You have to see I am getting beating from everyone. But is an important factor....I think tandem seating would yield a better trainer.
  6. Aug 18, 2019 #86
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    Inverse pressure gradient matching is a real thing....Mike Arnld explains it nicely. His term "poor mans area ruling " may be a bit misleading.
  7. Aug 18, 2019 #87
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    Is partial ownership same as like semistall ?
  8. Aug 18, 2019 #88
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    Fact is that with similar size fleet Pipistrel Sinus is 15 times more safe ( 15 x less fatalities ) than an EV-97. You cannot deny this...not with Dunning-Kruger or any other "hitler-card like BS" you try to impose.
  9. Aug 18, 2019 #89
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    This was one case...two died in an exercise where they tried to return to airfield after engine quit ( idle ).
    https://www.turvallisuustutkinta.fi...tutkintaselostus/b62009l_tutkintaselostus.pdf
    I flew the same maneuver with a friend of mine week after the incident with a Rallye Club ...and we had no difficulties.
    I think the EV-97 is ill suited for this kinda maneuvers.
    Rallye has proportionally bigger rudder and fuse is more streamlined all the way. It does not planket either. Also the elevator has been lifted higher...which could be a great benefit here..in regaining the flow back after a stall.
    https://en.wikipedia.org/wiki/SOCATA_Rallye_family It has way higher wing loading too.
  10. Aug 18, 2019 #90
    Wanttaja
    Wanttaja
    Wanttaja
    Sep 15, 2013
    1,185
    1,350
    Seattle, WA
    As I mentioned earlier, all my information is based on the US registry and US NTSB database. Not saying such accidents haven't occurred elsewhere, just that they haven't happened in the US.
    So you killed the engine without warning to the pilot to see how he responded.
    I'm guessing not.
    Without that surprise/stress factor, it isn't a fair comparison.
    I see the Finnish report you posted specifically calls out the instructor as being inexperienced, and not competent to perform the maneuver. Would you describe your friend in the same way? If not, then it's a bad comparison.
    Ron Wanttaja
  11. Aug 18, 2019 #91
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    He is very experienced and I actually did get goose bumbs for doing it, but he had it under control...during this maneuve the particular EV-97 had stalled already twice. We also have to remember that Rallye has slats and Fowler flaps. It is altogether a different kinda beast. I think my pilot friend was extremely upset and couldn't figure out why they failed...that is why he wanted to show me how elemental the move is ( in his opinion ) in a Rallye.
    I have actually also trained it with jets too in FSX...and you really have no second to loose or make a misjudgement..that is why they call it the move "impossible turn".
  12. Aug 18, 2019 #92
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    I counted that new solar cells would propel sleek flying wing of 14 m span giving 11 kw....if 3 pedalled inside it might have significant add...if there are clouds or head wind etc. HPAs can only rely on 250 watts.
    I pedalled a bike 150 km last week.
  13. Aug 18, 2019 #93
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,661
    1,625
    Upper midwest in a house
    So I have a question:
    Why don't you go to the aviation authority in your country and tell them the EV-97 is deficient? You can present your evidence to them and they will quickly move to ground the airplane, no?? Certainly they will not allow a dangerous plane to fly?
  14. Aug 18, 2019 #94
    12notes
    12notes
    12notes
    Aug 27, 2014
    793
    489
    Louisville, KY
    What, you mean you studied this subject in depth for years and read entire books on the theory and practice instead of reading the first result of a Google search on this one term you just heard about and mocking others for not knowing what the author renamed it to? Amateur.
  15. Aug 18, 2019 #95
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    I agree... I did mention that it is a "sling" ...RITSA in finnish...and they gave me a weeks worth bananas from local aviation forum.
    Thing is that Eurostar/Sportstar is a decent aeroplane in the hands of an experienced pilot....who know how aeroplanes fly. I can fly any kite at ease in FSX. F-35 possibly the most demanding of them...and MIG-21 F13.
  16. Aug 18, 2019 #96
    Wanttaja
    Wanttaja
    Wanttaja
    Sep 15, 2013
    1,185
    1,350
    Seattle, WA
    Okay, that's it, I'm out of here. Quoting a flight simulation game for your aviation expertise.....
    Ron Wanttaja
    Charles_says and bmcj like this.
  17. Aug 18, 2019 #97
    12notes
    12notes
    12notes
    Aug 27, 2014
    793
    489
    Louisville, KY
    "Well, your honor, we have plenty of hearsay and conjecture, those are kinds of evidence" - Lionel Hutz
    SVSUSteve likes this.
  18. Aug 18, 2019 #98
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    Okay !...:)
  19. Aug 18, 2019 #99
    SVSUSteve
    SVSUSteve
    SVSUSteve
    Aug 21, 2007
    3,847
    915
    Indianapolis, IN
    Thank you Fergie. I wasn't sure if it was the same one or not. Mea culpa on mixing up the aircraft type.
  20. Aug 18, 2019 #100
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    546
    39
    Europe
    I assume flight simulation is the only way to fly F-35 before you actually one.
