Crash rate ?
Discussion in 'Hangar Flying' started by Speedboat100, Aug 15, 2019.
  1. Aug 16, 2019 #41
    Wanttaja
    Wanttaja
    Wanttaja
    Sep 15, 2013
    1,187
    1,351
    Seattle, WA
    Charles_says and SVSUSteve like this.
  2. Aug 16, 2019 #42
    Wanttaja
    Wanttaja
    Wanttaja
    Sep 15, 2013
    1,187
    1,351
    Seattle, WA
    I hate to say it, but it's almost a "buzzword bingo" sort of situation. The OP uses a lot of terms to claim there's something wrong with the Evektor, but doesn't seem to understand what the terms actually mean or whether the features stated are actually out of the ordinary. "Adverse Yaw," "Area Rule," "Rudder authority," "Bigger rudder," "straight wing," etc.
    Ron Wanttaja
    BJC and SVSUSteve like this.
  3. Aug 16, 2019 #43
    SVSUSteve
    SVSUSteve
    SVSUSteve
    Aug 21, 2007
    3,855
    916
    Indianapolis, IN
    I almost broached that but figured that he was already badly confused since he was conflating the blanketing of the rudder by the elevator with "prop wash".
    It seems like Speedboat really needs to go read up on aerodynamics and light aircraft design before this conversation goes much further. I would suggest Raymer's "Simplified Aircraft Design" and Thurston's "Design for Flying" as starting points.
  4. Aug 16, 2019 #44
    9,353
    6,129
  5. Aug 17, 2019 #45
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    4,807
    1,285
    Marion, Ohio
    High performance aerobatic planes are supposed to be marginally stable, like fighter aircraft, in order to get the needed maneuverability. In fact, modern jet fighters are so unstable that they can not be flown by the pilot. The pilot tells the computer what he wants and the computer does the actual flying.
  6. Aug 17, 2019 #46
    9,353
    6,129
    Agree with that, but I don’t understand how that relates to my post that you quoted with your post.
  7. Aug 17, 2019 #47
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    577
    41
    Europe
    Right...but a rudder like that causes a roll to left if you wanna turn right. Adverse roll perhaps ?
  8. Aug 17, 2019 #48
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    577
    41
    Europe
    I know that "poor mans area rule" is actually pressure gradient matching ( in subsonic aeroplanes ) ! It is a bit sad that none of you understood this phenomena.
  9. Aug 17, 2019 #49
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    577
    41
    Europe
    No way to tell...but loss of directional control was the issue in many cases ?
  10. Aug 17, 2019 #50
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    577
    41
    Europe
    Can you enlighten us with those design factors ?
    I can see here ( english summary ) that 96 km/h stall speed is also very dangerous ( Cora 200 Arius F ): https://turvallisuustutkinta.fi/mat.../2013/e9Oc5u25v/Tutkintaselostus_L2013-03.pdf
    A very dear friend of mine perished in this as a passenger.
  11. Aug 17, 2019 #51
    Wanttaja
    Wanttaja
    Wanttaja
    Sep 15, 2013
    1,187
    1,351
    Seattle, WA
    I assume you're referring to an aileron-like effect when the rudder moves, but how is it different on the Evektor than any other airplane? If you're claiming the plane's rudder is too small, would it have LESS of the "Adverse Roll" effect you're concerned about?
    In any case, in just about all normally-configured aircraft, pressing a rudder causes the plane to roll IN THE DIRECTION of the rudder press, not "adversely."
    I normally don't ask this, but I think this time I must: What is your level of flight experience? I'm sorry, but a lot of your questions seem to deal with obscure theory without seeming to understand how airplanes actually work.
    Your sneering reference to those who are honestly trying to answer your questions ("It is a bit sad that none of you understood this phenomena") makes you look a bit trollish. It looks more like you're just trying to bad-mouth an aircraft rather than seriously discuss the issues.
    Ron Wanttaja
    SVSUSteve likes this.
  12. Aug 17, 2019 #52
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    577
    41
    Europe
    Ron the position of the rudder is well above the centerline of the short fuselage...it is pure physics. My flying hours are irrelevant in this. They are very low..mostly R/C models.
  13. Aug 17, 2019 #53
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    577
    41
    Europe
  14. Aug 17, 2019 #54
    SVSUSteve
    SVSUSteve
    SVSUSteve
    Aug 21, 2007
    3,855
    916
    Indianapolis, IN
    Yeah....about that...
    That explains almost this entire discussion and why you’re not grasping how real planes work which we have repeatedly explained to you.
    I am sorry about your friend but you’re doing a disservice by being stubborn and refusing to listen to those with more knowledge and applicable experience. The only thing that you’re doing is making it pointedly clear that you don’t even understand the most basic “physics” of how an airplane flies.
    pictsidhe, Charles_says and Wanttaja like this.
  15. Aug 17, 2019 #55
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    577
    41
    Europe
    Hand on the bible SVSUSteve...would this make the directional stability worse or better ?
  16. Aug 17, 2019 #56
    9,353
    6,129
    Sigh ...
    Select “Speedboat100”
    Select “ignore”
    Give up trying to assist ...
  17. Aug 17, 2019 #57
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    577
    41
    Europe
    Sorry BCJ. You wanted to teach me...and not advance aviation safety...I am sorry.
  18. Aug 17, 2019 #58
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    577
    41
    Europe
    Here is a good and sound vertical stab and a rudder.
    Does someone disagree ?
    Tapered wings and a large rudder.
  19. Aug 17, 2019 #59
    SVSUSteve
    SVSUSteve
    SVSUSteve
    Aug 21, 2007
    3,855
    916
    Indianapolis, IN
    Yup. I’m out.
  20. Aug 17, 2019 #60
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    577
    41
    Europe
    Yes I am sorry...I understand that I have not used the correct term for adverse roll...and SVSUSteve has a good point about the planketing.
    I only try to enhance the safety...with limited means...seeing what I see is wrong...and reading what clearly indicates a problem.....and speaking openly about it.
    I find this as a fine example of a low wing well organized: https://en.wikipedia.org/wiki/Scottish_Aviation_Bulldog
    ...and where is Autoreply these days ?
