Contra rotating propellers
Dusan
Sep 15, 2014
98
Canada
From disk actuator theory, a "maximum value" of thrust can be easily calculated, and for a 100HP, 1.7m diameter propeller, a thrust "maximum value" of 319Kg is calculated. For a good propeller, you should get to 0.8-0.9 of that, that's about 270Kg thrust. So, as you are not even close to that value, I suspect something is wrong with your setup, either the engine is not matched to the propeller, or most likely your propeller is stalled, as you mentioned the noise.
For 70HP, same diameter disk, the theory predicts 252Kg "maximum value" thrust, your setup has 0.91 of that. As you're getting such a high value, I suspect you have some fresh inflow on the aft propeller, that effect is noticeable from 0.2d rotor separation(Leishmann). Keep in mind that the effect is lost if there is too little separation, or if the props are ducted.
Number of blades. Less blades are always more efficient. A 0.1m blade moving trough air at 200m/s is having about Re=1,400,00. A 0.05m blade is having Re=700,000. For Clark-Y airfoil the max L/D ratio decreases more than 15% with the decrease of Re. That means more blade drag needs to be overcome by motor torque for the same lift(thrust)
dino
Sep 18, 2007
680
florida
Torque roll in gyroplanes with decreasing disc load-decreasing rotor thrust during push over
henryk
Mar 8, 2010
5,371
krakow,poland
-can I get some examples ? (practice...)
-russian heli constructors have practical formula for propellers comparation=
("finesse coefficient")
Kf=("specific thrust") * sqr ("load phactor") =( kG/HP ) * (kG/m^2) ^ 0.5
f.e. ="auer" differential CR=
Kf=( 230/70 ) *( 230/2.3 ) ^0.5= 3.3 * 10= 33
Dusan
Sep 15, 2014
98
Canada
It looks similar to McCormick formula, I'll look into this, Henryk, give me a couple of days.
henryk
Mar 8, 2010
5,371
krakow,poland
F=m*a a=dV/dt,
F=m *( a1 + a2 ).
BTW=propeller in sum accelerates air molequles,
but NOT DIRECTLY (as tennis racket or turbomolecular pump do).
propeller ONLY works as vacuum pump =decrease pressure in own disc...
air molequles,thanks its own kinetic energy (E=2/3 kT) accelerates (average speed is gained)
and go away thanks its own inertia...
PS=iff temperature is close to condensation point we cant fly on wings and propellers,
only jets can moove !
Dusan
Sep 15, 2014
98
Canada
F=m *( a1 + a2 ).
This is essentially correct, and F=2*rho*A*vi^2; but P=F*(vi+v0). For the first propeller the v0=0(static condition) but the second prop's v0 is "seeing" induced velocity from the first one, so the second prop needs more power for the same thrust. If you want to use two propellers, it's always best to put them side by side.
henryk
Mar 8, 2010
5,371
krakow,poland
=side by side=double surface, but we have place for only one !
=in auer case (differential gear !) the RPM of propellers is anti-proportional to the drag momentum of them... (selfoptymisation).
Sockmonkey
Apr 24, 2014
1,915
Flint, Mi, USA
Honestly, gryocopters are so fiddly with their handling I'd just live with the extra drag of using twin rotors on booms synchronized by an interconnecting shaft so their respective disks could overlap without flexing into each other.
Swampyankee
Dec 25, 2015
1,428
Earth USA East Coast
Not that again.
No. Fewer blades are not always more efficient. We've discussed this numerous times in the past. Like any other lifting device, a propeller's drag is from a mix of induced and skin friction drag. Increasing the number blades reduces the total induced drag. The optimum number of blades is the greatest number that a) doesn't run into adverse Reynolds' number effects (in your case, if a Clark Y*'s properties aren't good, you switch to a different airfoil) b) doesn't run into structural problems at low speeds (constant speed propellers, at least, are operating with extensive areas of stalled flow during the takeoff regime) and, c) doesn't run into choking in the blade roots (you need at least seven or eight blades and a operating Mach number of about 0.7 for that, and it's correctable by adjusting the spinner's contour).
For constant-speed props, a complicating factor is that more blades reduces the loads on the pitch change bearings and the pitch change actuators.
* There are a lot of airfoils that are much better than the Clark Y, but what's more important is that there are airfoils that are designed for operation at low Reynolds' numbers.
dog
Dec 29, 2019
301
Theodorsen, Dowty-Rotol, and Tupolev Design Bureau disagree.
The transport version of the Tupolev ,could be encouraged to run the props with the tips running
supersonic, and the fuesalage skins adjacent would crack from the sound/vibration, so they put on thicker skins, read about that in a snipet about a joint soviet/japenese airline
mcrae0104
Oct 27, 2009
3,379
davidjgall
Oct 7, 2010
59
Northern California, USA
The transport version of the Tupolev could be encouraged to run the props with the tips runningsupersonic, and the fuesalage skins adjacent would crack from the sound/vibration, so they put on thicker skins, read about that in a snipet about a joint soviet/japenese airline
Wow! That had to be even louder than the already legendary loudness of the standard “Bear.” Shades of the XF84-H “ThunderScreech!“
jedi
Aug 8, 2009
2,156
Why is that? I would have thought it would be the other way around.
Same reason buzzards have the multiple wing tip feathers and the elliptical wing has the minimum induced drag. More vortices but each one is a fraction of the total vortex strength. The power of a vortex increases exponentially with the strength. The power in a single vortex is greater than two times the power in a vortex half the size. Induced drag is a function of the square cube relation between speed, force and power of the downwash.
Sockmonkey
Apr 24, 2014
1,915
Flint, Mi, USA
Ohh, gotcha.
