Now if we could just convince you to (1) machine a new flywheel with a nice high-inertia ring at its perimeter, and (2) install a real honest-to-gosh engineered soft coupler to replace those horrible urethane bushings...![]()
Hey, it works!
Hey, it works!
Sort of. Ever work with urethane bushings and drive pins? The urethane has so much hysteresis that it compresses at the first power stroke and stays compressed in the hertz range, result being lots of system lash (free play at the drive pins), in particular when in resonance.
Big difference with an engineered coupler like a Centaflex. Rubber has far less hysteresis, it's preloaded in compression, cannot develop lash of any kind, and the stiffness is a known spec sheet value.
I'd have liked Ross incorporate one, at a softer spring rate. He will cheerfully tell you it still resonates well above idle. Adding the perimeter slugs (adding flywheel inertia) lowered the amplitude some, but doesn't move frequency very much.
How much? If I drag out real data for an early iteration of my Suzuki drive and plug it into the Holzer code, a 50% increase in element 1 inertia (crank and flywheel) results in a 3.5 hz frequency reduction. That's only 131 RPM for the 3 cyl, or 105 RPM for a 4 cylinder. Not much.
Why not a solid ring bolted on?So many lessThe flywheel weights were nested in tight fitting recesses so the bolts are not under shear. Russell Sherwood had Guy Marcotte machine a custom steel flywheel the 2nd time around on his EG33. I think it was 12-14 pounds. Mine is 15 pounds now, up from 7.
parts and it could be balanced after install.
As I said, these are not urethane.
I can't go any softer here as the present setup has a deflection of 1 deg per 25 lb./ft. at 15C.
The only reasonable course without massive time and expense was to add flywheel mass.
Was one of your considerations how close to the edge you put the weights,to prevent cracking?Cost of a slice of 12" shafting and machining time to take the center out of it. The CNC lathe with bar puller can spit out 16 of these weights in about 45 minutes from cheap material. The mill can cut the pockets and drill the holes in less than 20 minutes. Plus this looks cooler... Balance wasn't affected. Also if this didn't work, I could remove all the weights without removing the gearbox.
Ahh, please excuse me, faulty memory. Found the photo. Is that a Malcorp suspension bushing? Got an application, part number or catalog page?
Rubber Automotive Parts Manufacturer & Exporter - Malcorp
We manufacture & export various type of rubber automotive parts including engine mounting, rubber bushes, center bearings & more. Contact us for more info.malcorp.net
That's soft....but it maintains that rate for how many degrees of angular displacement before rising very rapidly?
And there we arrive at the key. Folks here are interested in designing drive systems, and you're a respected man. So, some will look at the flywheel photo and think "Oh yeah, pins and rubber bushings must work fine", not realizing it was a design feature retained only because improvement would have required modifying the Marcotte. Yes, it works, sort of. An engineered coupler would perform better, torsionally speaking, and on the practical side, it would last for more operating hours.
Now, are you finally coming to OSH this year to have a beer with me?
Hmm. My memory of Ross' details is fuzzy, so I hit the advanced search tool. Look at Ross' input: More Thoughts on PSRUs post 166.
If engine idle speed is set somewhat above resonance, we are are already on the isolating side of the curve.
Ross ran 400 hours in the original form without breaking anything, so it was, at minimum, somewhere around acceptable. The new form is smoother everywhere it is operated and has to be easier on stuff like bearings, gear sets, and props, not to mention more pleasant to operate.
The rate was pretty linear to about 100 lb./ft. then started ramping up. I only went to 150 as that was the limit of the torque wrench. That's pretty soft and doesn't do much at resonance where I'm guessing torque may exceed several hundred lb./ft.
The bushings are Moog K6176.
I suspect Guy Marcotte didn't have a good understanding of TV and that applies to most of us in our younger years as well without the formal education and vast real-world experience that Bill has.
Due to the return restrictions back into Canada now, I can't travel to the US at all. Looks like I'll miss Reno too also unless something changes soon.
On the pipeline, we use our calibrated hands to judge the bearing temps on the big prime mover (900hp) pumps. If you can't keep your hand on it for ten seconds, better spin up a spare pump and get the hot one looked at.And if a series of runs were made at different
rpm's,just stopping the motor and useing your
hand would suffice.
Lots of mechanics will do this to trace problems.
Shaky loose or high friction things get hot.
