Australian Opal and others
Aircar
Banned
Feb 20, 2010
3,567
Melbourne Australia
Opal amphib 1976.jpgRick McWilliams asked about posting a photo of the Opal so, with a lot of help from a friend here is a scan of a couple of photos from the deep archives .
It was illegal to build both aircraft in Australia -- without fully complying with FAR 23 and additional fatigue tests full flutter survey etc BEFORE any test flight being allowed --there was no experimental category until 1999 --only imported kits and designs (plans) were totally exempt from certification --the story would require a book but not here.
The Opal was intended to be amphibious and rough dirt field capable hence the "platypus tail" shielding the prop (and fold down rear fuselage panels ) --the hull was not yet built in in this photo nor the mid wing floats --similar to Molt Taylor's Coot in floatwing with outriggers folding into the float blisters . Stiletto was flown in 1983 and resulted in me being prosecuted (again) --wings destroyed but I still have the fuselage and canard in the trailer --built a sidecar from the molds also and I will see if I can send some more photos . these are relatively conventional aerodynamics but this thread might be easiest to direct them to . Hope this sends OK.
Tom Nalevanko
Oct 10, 2007
1,316
Alpine, WY
Re: Revolutionary or counter conventional aerodynamic principles
Interesting design; thanks for posting the pix...
Tom Nalevanko
Oct 10, 2007
1,316
Alpine, WY
Very interesting; we like pictures! What does the first picture (the sketch) show?
Blue skies,
Tom
henryk
Mar 8, 2010
5,019
krakow,poland
Blue skies,
Tom
Obraz 0309+ 395.jpgObraz=SONY,rysiek,bekas,pobiednik 046.jpg,bogdan.laminat 006.jpg,bogdan.laminat 005.jpg
=flat G16+starter-generator+KASPERwings+3-place fuselage with pressurised/vacuumrised floats+3-wheel with hubmotors...
fly2kads
Jan 2, 2010
1,513
Justin, TX
Very interesting aircraft!
I think we in the U.S. tend to forget sometimes what a unique environment we operate in. It is hard for us to imagine being prosecuted for designing and building something as benign as a small airplane.
DaveK
Apr 21, 2007
344
Northern California
Especially those that say "I'll just pay someone to build my airplane for me". We all need to protect this special category we have in the US.
WonderousMountain
Apr 10, 2010
1,853
Clatsop, Or
Huh, I've often considered being prosecuted for flying my aircraft (no license), but only rarely has it crossed my mind that it might be ill-eagle to build my aircraft. The government doesn't mess with business interests here very often. We'd be more likely to ask for a bribe than destruction. Although, much of that stopped with the invention of micro-recorders.
WonderousMountain
Apr 10, 2010
1,853
Clatsop, Or
Oh beautiful aircraft, whomsoever destroyed the wings ought to be flogged with a wet towel and left in a pasture to ripen for a day or so.
billyvray
Aug 17, 2005
735
Newnan, GA
Henry,
I searched for more info on this G10 conversion and found posts by you and a link to your projects on the REaa site. I ask of you two things:
1) Please start your very own thread detailing your projects. You have some wonderful projects (especially with engines!).
2) Please provide more info on the G10 conversion. Is is manufactured? Is it someones experiment? I could not really determine.
Thanks, keep up the good work.
Bill
henryk
Mar 8, 2010
5,019
krakow,poland
Bill,I am only very bad writing english conductor between Bogdan and Forum...
Kasperwing.com international content
=Bogdan=black head,in shirt...
reduktor,bogdan 015.jpg=Bogdans new reductor for G-motors\10 kg,with spring dempfer\
=reductor is made from orginal SUZUKI details=no mantains problems.
=no serien production.
-motor G10 with turbo is comparable with G13=not turbo\power,weight\.
but G13,16 is moore comfortable\no vibrations\.
=summ.weigt of motor+reductor+frame+propeller=cirka 90-100kg.
flyoz
Jul 30, 2008
149
Near Sydney
"Stiletto was flown in 1983..."
Any other information? Looks like a Varieze scaled down ?
Cheers
Flyoz
Aircar
Banned
Feb 20, 2010
3,567
Melbourne Australia
Back again-- The Stiletto was started as a pod and boom ultralight intended to comply with the then new category ANO 95 10 (Air Navigation Order -- similar to FAR ) which specified an AUW of 400lbs and wing load of 4 lbs/ft sq and which restricted the operation to BELOW 400 ft above ground and prohibited flying across asphalted roads (!) -- almost none of the aircraft built to this category conformed or obeyed the restrictions both of which were ridiculous and unsafe . (and unenforcable in several respects ) Then the rules were further restricted after one particular aircraft was found to be almost the full AUW when empty and horribly unairworthy by design so in order to protect the culpable officials involved everything was grounded by strict application of the wing load limit in particular .
The Stiletto was an attempt to meet the weight limit ( under 50Kg empty - Solo 210cc engine) AND to meet the wing loading by having a high Cl canard which unloaded the wing sufficiently to comply (also with a third forward swept wing mounted behind the pilot's head which straddled the Cg and was 'optional' but got the design under the net wing loading limit -- in order to get some useful cross country speed in a category which otherwise amounted to a powered umbrella .
Yes it is almost exactly a scaled down Vari Eze just to minimize the unknowns.
It could be also seen as a scaled up 'Super Snooper' which was the progenator of the Vari Eze built by Fred Jiran in hot wired glass composite (a UAV carrying a nose camera -- I went through Edwards AFB with Fred in 1975 to 'help' repair the F15 free flight drop test model and the Super Snooper and came across the prototype Vari Eze next door to Fred's workshop then --Fred was making cowlings and bits for Burt Rutan (Vari Viggen ) and some for the Eze to which I leant a hand.
Despite the clear wording of the airworthiness standards that "balancing tail loads must be taken into account in calculating wing forces" they rejected the proper definition of wing loading and made the Stiletto illegal -- I had flown it from an airfield where I used to test fly gliders after major repairs (meaning they had no certificate of airworthiness in force when I flew them --all on a permit to fly issued under my authority and only after satisfactory test flight was the CofA restored -- I did the same thing with the Stiletto and flew it at 6.00 am first with no other traffic etc but the Department of Aviation even went to the extent of demanding a witness report from the airfield groundsman to try to get a prosecution for flying an uncertified aircraft etc etc .
Google 'Dick Smith / CASA reform' or something like'incompetence and corruption in Australian aviation regulation' for more insight into the mis management of aviation here if interested --Dick Smith was first to fly a helicopter solo around the world and wrote a book called "Two years in the aviation hall of doom' detailing the unbelievable bloody mindedness and incompetence in our "FAA" --he called for a Royal commission to investigate the whole mess. Another book could be written ...
The Opal was the first fully molded kit aircraft in the world as far as I know -- it was only possible to do the tooling and design without being prosecuted and anyway I doubted that homebuilders could do quality control well enough for primary structure or would put up with the messiness and finishing time for external lay up . (Vari Ezes were limited to 2.5G by Rutan after a wing failure disclosed material properties way below design spec -- I had concluded while building glass gliders in Germany that there were too many ways to end up below par without extensive tooling and process control )
It seemed to me that there was a place for a high performance amphibian since there was nothing much at the average airfield, especially inn the heat of summer , for any recreational activity --everyone heads for the sea or a river lake etc to get some holiday pleasure --not to an airport, so a recreational aircraft should be able to get away from an airport (also land in paddocks hence have full propeller protection and not be susceptible to flipping over itself like aircraft jacked up on undercarriage legs ) --the end was to be a roadable version which again favours a low cockpit and undercarriage etc ).
flyoz
Jul 30, 2008
149
Near Sydney
Interesting stuff !
Did the canard have the normal elevators and what were the canard tip extentions ?
Do you have any photos of the "Super Snooper " or any other history ?
The standard Varieze canard chord is already fairly small - it looks like the Stiletto canard chord relationship is slightly bigger than if it was scaled - in other words closer to Varieze chord ?
How did it fly?
Thanks
Flyoz
Aircar
Banned
Feb 20, 2010
3,567
Melbourne Australia
The canard was the GU 25% T/C section --designed for a man powered aircraft at Glasgow university -- same slotted flap geometry as the Vari Eze and about the same chord (expanding slot with full back stick intended to limit control authority and give nil stall --the flap flow separates but the canard itself cannot be let stall -- I never stalled it and in fact only flew a number of straight runs down the runway at up to 100ft . Initially there was a real rotation problem due to thrust moment and I built a "trim" surface that came out on a single arm behind the prop and which was slaved to the throttle (looking a little like a formula one rear airfoil and lifting down also --I have a couple of old photos of it emailed to me by a friend that I will try to send .
This seemed to work as desired and no longer needed full back stick and a high rotation speed (in fact the very first high speed taxi tests turned into an inadvertent 'hop' after rapidly reducing throttle removed the thrust moment and still had back stick...... at the time the cockpit was filling with acrid smoke from the baffle material 'cooking' by contact with the tuned exhaust pipe (it then loses volatiles and settles down but I didn't know that at the time ) the extensions on the canard are like Spillman tipsails and also add stick forces (like the antibalance tabs on the Monerai V tails --they operate in the upwash outside of the tip so see a higher change of local alpha versus aircraft 'deck angle' .
The Super Snooper might be on Google --it had a hydrazine engine and was intended to fly over 'hostile' borders undetected (composite airframe) and then descend to take photos and return --it became unstable at great height apparently and got relegated to atmospheric sampling as the Mini Sniffer and even contemplated for the Marsplane -- Einar Enevoldson (NASA)was involved somehow and was also a partner in a Phoebus with Fred Jiran and they extended the wingspan using hot wire core glassed over in model aircraft fashion and built the Super Snooper the same way. (Fred had learned European glass glider techniques with Diamant in Switzerland and then went around the world doing factory repairs and modifications that had to be done as a result of hidden construction defects --I met Fred at Waikerie in 1967 and looked him up again in the states (1974 ) he helped with materials to build the prototype HP 18 . NASA had a information sheet on the Super Snooper at one time but not sure if it is still available.
I 'retired' the Stiletto after deciding to modify it to become a sort of poor man's Starship --with two Solo 210s mounted on the centre section (I'll send a few photos when I can find them ) --I couldn't afford a second engine at the time and other events intervened (another story...) -- A friend wants to revive it now and we opened up the trailer a year or so back and had a look at the state of the aircraft -- making new outer wings would not be too difficult and there are better engines available now (the noise was horrendous with direct drive,no firewall or noise barrier and 7000 RPM I ft behind your head -- due to circumstances at the time the planetary gearbox reduction was not ready and other shortcuts were required) I think the Starship configuration would be quite good --the much bigger curved strakes increase the fuel volume and give heaps of elbow room as well and a much deeper root spar )the wing is a sort of' Eiffel tower' planform for minimum weight and there is no longer any ridiculous weight limit or operational stupidity (now based on pilot qualifications ) twin engines with low assymetry would give reliability and low noise in the cockpit (unlike the otherwise excellent Cri Cri twin where the exhausts are next to your ears )
One of the best features of the Stiletto was the ground handling --"bicycle" layout but tricycle weight distribution --with tip wheels on sprung arms --the nose wheel retracted and the main gear was sprung by the glass shell and worked well
flyoz
Jul 30, 2008
149
Near Sydney
Thanks Aircar
Congratulations on building and flying it !
Good history - when somebody writes a definative Varieze story your project and the "super Snooper " will have to be in it !
I tried searching for the super snooper but could not find much
The Stiletto wing area looks quite small - 4 lbs wing loading @ 400 lbs max is still 100sq ft ( as you say you tried to include the canard )
The standard Varieze only has about 54 Sq ft ? any idea what the Stiletto scale was ?
Flyoz
