Arduino altimeter & airspeed indicator
6,757
\ Wonder how the pin outs are. Would they be in the standard libraries?
A quick Google finds both the data sheet and some arduino code. Funny looking little chip......but probably worth the extra $'s and time.
Good tip! No more BMPs for me.
Scheny
Feb 26, 2019
168
Vienna, Austria
I even have a better idea: Google for 10DOF IMU boards. They build them for small drones and you will get a controller and sensors in one 2x2 inch package. There are ones featuring Arduino, but I would suggest to go for something like a "Naze32".
This is built upon a STM32 processor which is more in the Raspberry league and you can get it with either a built in BMP180 or HS5611 for around 30$.
There are multiple open source software versions available (like "Betaflight" etc.) including the drivers. So even if you don't buy one, download it and you have the drivers.
As there is 3D gyro and compass and accelerometers available, I would strongly suggest to use the vertical accelerometer in compound, as this is most reliable for short term variometer changes (i.e. with some 2 dimensional Kalman filtering algorithm). You could also make some backup compass functionality available by button selection if you want.
Bill Welter
Jun 10, 2019
20
The Arduino code on the websites I found have errors and are incomplete. I got the Arduino, wrote the code for airspeed, and to display the speed up to 110 kts or 125 mph (limit for the 2 kpa sensor) on three 7-segment LEDs. It's actually pretty accurate! I can forward the code and pinouts if needed.
Hephaestus
Jun 25, 2014
1,468
YMM
Green is the most sunlight readable. Put a proper filter over it and go red would be my preference
7,009
Thanks, Hephaestus, but please explain. If green is most readable in sunlight, why go with red, and what exactly is a "proper filter"?
Hephaestus
Jun 25, 2014
1,468
YMM
Because when you're out flying in theory there's probably a fair bit of green around. The red stands out and you're trained to seek that red light already. Prrsonal preference for me - I really dislike the green light dashlights on cars, I like the red.
Filter is a diffuser, most have them already but that simple plate to keep the glare down and make them more visible.
10,489
Apart from readability, the color red on any aircraft display carries the connotation that the measured value is outside of the desired range.
7,009
Personally, I think that an LED display in a neutral color with separate single RGB LED (or individual LEDs of different colors) makes the most sense.
At one point I sketched out a generic display with a simple square black 1/8" aluminum backing plate, round smoke acrylic or polycarbonate window to fit a standard instrument hole, 3D-printed rear enclosure, white 4-character alphanumeric LED display, rotary encoder (turn left or right or push knob), and an RGB status LED. The idea was that all of those components and the basic Arduino controller would be standardized and only the programming and the sensor would change to make an altimeter/variometer, airspeed indicator, compass, etc. A color-coded decal (icon or ring around the face) or maybe an icon laser-etched in the window would show the function of each instrument at a glance.
I didn't pursue it because my Arduino programming skills are very basic and the various components for one added up to almost as much as a cheap analog instrument. Also compact multifunction instruments like those from MGL do more for less than a whole panel of homemade ones.
Hephaestus
Jun 25, 2014
1,468
YMM
I think there's probably some strong logic in doing the previously mentioned Arduino(ish) MFD.
SainSmart 3.2" TFT LCD Display + Touch Panel + PCB Adapter SD Slot for Arduino 2560 UNO R3 Mega Nano Robot https://www.amazon.ca/dp/B008FWSG3S/ref=cm_sw_r_cp_apa_i_GrsaDbBXQCCX9
Aukru MPU 6050 Module 3 Axis Gyroscope+ 3 Axis Accelerometer Module for Arduino,arduino Accelerometer, https://www.amazon.ca/dp/B019SX74TE/ref=cm_sw_r_cp_apa_i_rssaDbEW2D0HG
MyRobotUniverse GPS Module GY-NEO6MV2 NEO-6M with Flight Control EEPROM RS232 TTL Large Antenna for Arduino Raspberry Pi GPS APM2 APM2.5 NEO6MV2 3-5V https://www.amazon.ca/dp/B07KSJLXXT/ref=cm_sw_r_cp_apa_i_-AsaDbTDXVVAA
Throw in a couple air pressure sensors...
A simple light inexpensive open source MFD for ultralights and experimentals. Air/ground/true airspeed a attitude indicator gps tracks etc. It would be pretty awesome.
7,009
ePaper/eInk displays (like a Kindle, Nook, etc.) are getting cheaper and faster. Some have three colors (white/black/red for example) but they can take a long time (>10 seconds) to refresh the image. Some of the plain black/white ones have a refresh rate of just 1-2 seconds. The displays use very little power (no backlight required) and are sunlight readable so I can definitely see them working well for instruments as the technology evolves.
Charles_says
May 26, 2019
137
Please do forward the code and pinouts to me
TIA!
Bill Welter
Jun 10, 2019
20
I'm using 3461BS LED chip, which comes in different colors, only using the right three digits. The pressure transducer is the common MPXV7002DP . I'm using a small switch to select knots or mph. I prefer knots, but when its set to mph, the decimal points on the chip light up to tell the pilot he's looking at MPH. I'll write down the pinouts later, here's the code:
#include <Esplora.h>
#include <Wire.h>
#include <SPI.h>
int Corr = 0; // 0 pressure is ~offset 555 on the sensor
int Sensor1 = 0;
int OffsetC = 0;
float AirSpeed1 = 0.0;
int AirSpeed1R = 0;
float MagicNum = 1.06; // to make the system match a real gauge
int Switch = 0; // 0=Knots, 1=MPH
int TimeOn = 1; // LED lit time, in MSec
int InterDigitTime = 7; //MSec delay before next digit is lit
int Thousands = 0;
int Hundreds = 0;
int Tens = 0;
int Ones = 0;
int SegA = 2;
int SegB = 3;
int SegC = 4;
int SegD = 5;
int SegE = 6;
int SegF = 7;
int SegG = 8;
int DP = 9;
int Digit1 = 13;
int Digit2 = 12;
int Digit3 = 11;
int Digit4 = 10;
// Functions
void DisplayDigit (int Dig, int Num) /////////////// Displays the digit
ClearAll ();
if (Dig==1) {digitalWrite(Digit1, HIGH);}
else if (Dig==2){digitalWrite(Digit2, HIGH);}
else if (Dig==3){digitalWrite(Digit3, HIGH);}
else if (Dig==4){digitalWrite(Digit4, HIGH);}
if (Switch <20) {digitalWrite (DP,LOW);} // Turn on decimal point if switch set to MPH
if (Num==0)
{digitalWrite(SegA, LOW);
digitalWrite(SegB, LOW);
digitalWrite(SegC, LOW);
digitalWrite(SegD, LOW);
digitalWrite(SegE, LOW);
digitalWrite(SegF, LOW);
if (Num==1)
{digitalWrite(SegB, LOW);
digitalWrite(SegC, LOW);}
if (Num==2)
digitalWrite(SegG, LOW);
digitalWrite(SegD, LOW); }
if (Num==3)
digitalWrite(SegG, LOW);}
if (Num==4)
{digitalWrite(SegF, LOW);
if (Num==5)
digitalWrite(SegD, LOW);}
if (Num==6)
if (Num==7)
if (Num==8)
if (Num==9)
void ClearAll ()
{ digitalWrite(Digit1, LOW);
digitalWrite(Digit2, LOW);
digitalWrite(Digit3, LOW);
digitalWrite(Digit4, LOW);
digitalWrite(SegA, HIGH);
digitalWrite(SegB, HIGH);
digitalWrite(SegC, HIGH);
digitalWrite(SegD, HIGH);
digitalWrite(SegE, HIGH);
digitalWrite(SegF, HIGH);
digitalWrite(SegG, HIGH);
digitalWrite(DP,HIGH);}
// MAIN ///////////////////////////////////
void setup()
{ pinMode(SegA, OUTPUT);
pinMode(SegB, OUTPUT);
pinMode(SegC, OUTPUT);
pinMode(SegD, OUTPUT);
pinMode(SegE, OUTPUT);
pinMode(SegF, OUTPUT);
pinMode(SegG, OUTPUT);
pinMode(Digit1, OUTPUT);
pinMode(Digit2, OUTPUT);
pinMode(Digit3, OUTPUT);
pinMode(Digit4, OUTPUT);
Serial.begin(9600); // initialize serial communication at 9600 baud
Corr = analogRead(7);} // get 0 pressure on startup
// this loop routine runs over and over again forever:
void loop()
{Sensor1 = analogRead(7);// get the offset, max vacuum -2kpa = 0, ambient air pressure is about 554
// and max pressure 2kpa = 1016 ;
Serial.println(Sensor1); // debug
Switch = analogRead (15);
OffsetC = Sensor1 - Corr; // so from now on 0 pressure = 0 offset
AirSpeed1 = (sqrt(OffsetC*36.749*MagicNum))*0.868976;
AirSpeed1R = AirSpeed1; // 1R is INT and this rounds down
if ((AirSpeed1-AirSpeed1R) > 0.499)
{(AirSpeed1R = AirSpeed1R+1);} // round to nearest Int, up or down
if (Switch < 20) { (AirSpeed1R = AirSpeed1R*1.1504);} // Display Switch set to "MPH"
// Serial.println(AirSpeed1R); // debug statement, prints the speed that should be displayed to the serial port
Thousands = AirSpeed1R/1000; // break the integer down into 4 separate numerals to be displayed
Hundreds = (AirSpeed1R-(Thousands*1000))/100;
Tens = ((AirSpeed1R-((Thousands*1000)+(Hundreds*100)))/10);
Ones = (AirSpeed1R-((Thousands*1000)+(Hundreds*100)+(Tens*10)));
if (AirSpeed1 < 112) // Max for the 2kpa sensor is ~115 kts
if (AirSpeed1R > 999)
{ DisplayDigit(1,Thousands);
delay(TimeOn);
ClearAll ();
delay(InterDigitTime);}
if (AirSpeed1R > 99)
{DisplayDigit(2,Hundreds);
delay(TimeOn);
ClearAll();
if (AirSpeed1R > 9)
{DisplayDigit(3,Tens);
delay(TimeOn);
ClearAll();
DisplayDigit(4,Ones);
delay(TimeOn);
ClearAll ();
} // end of main loop
Charles_says
May 26, 2019
137
#include <Wire.h>
#include <SPI.h>
// Snipped for brevity
// End snip
} // end of main loop[/QUOTE]
Sincere thanks for your time and EFFORT!!
Charles.
Bill Welter
Jun 10, 2019
20
Good write-up by Adam Drees on the 3461BS 4-digit, 7 segment LED chip. I chose that chip because the digits were the right size for my needs: https://www.adamdrees.com/tag/3461bs/
The chip uses 12 pins to light up the LEDs. Here are the chip pins (left column) and the pins I connected them to on the Arduino Mega (A/M). I didn’t know anything about Arduino a few months ago, and just ordered the Mega.
Top Row 3461BS...Arduino Mega Pin
D1.....................13
a....................….2
f.....................….7
D2....................…12
D3....................…11
b.....................….3
Bottom Row 3461BS...Arduino Mega Pin
e......................….6
d......................….5
dp.....................…9
c......................….4
g......................….8
D4......................…10
Mph/Kts switch - one side GND, other side A/M pin A15
Pressure transducer input from MPXV7002DP - A/M pin A7
N500BC
Nov 30, 2015
3
Bogotá Colombia , South America
Hi all! This got me thinking. I just bought a Stratux that works wonderfully on ipad. I use aerovie as the nav and backup attitude app. Connected to the Stratux I get a great and very accurate EFIS. However, all airspeed is really GPS Groundspeed. As a back up that is not a problem. It is almost more precise than the gps groundspeed on my Garmin aera 500. Attitude AHRS sensors are muuuuch better. I would say even better than my mechanical gyro of the C172 I rent.
Could it not be a better idea to get those Baro pressure/differential pressure sensors integrated to something like the Stratux and get the whole picture? Stratux receives ADS-B so it would definitely become a turn key solution. Furthermore, new iPhones and iPad are equipped with a baro sensor. Can´t they be all rolled into one to display both sensor dynamic/static pressure airspeed and alt as well as GPS groundspeed? I have NO CLUE of electronics or electrics but would think that half or more has already been done and integrated to Stratux. There is also this new wingbug thing https://www.wingbug.com which mounts out on the wing. But for $950 dollars I'd much better wnat to integrate the above to Stratux and have a whole system for around 300 bucks! For 950 I'd buy the AvMap ultra EFIS
Hephaestus
Jun 25, 2014
1,468
YMM
What might work better is actually just doing like bill did, but outputting via Bluetooth serial, then it's just getting the app builder to add a way to take and display that data.
Charles_says
May 26, 2019
137
I started playing with the Arduino about a year and a half or so ago
Starting to get curious about Can Bus, Where separate sensors "talk" to the Arduino and ....can be remotely mounted, similar to what the automobile industry uses.
Thanks again Bill!![/QUOTE]
Latest posts
