An argument in favor of multi-engine design
7,295
There were some experimental 1920s designs and I think a few during WWI with fuselage-mounted engines driving wing-mounted propellers via shafts or belts or both. Here is one, the Parnall Possum.
Has there ever been a airplane with a fuselage mounted engine driving two or more wing mounted propellers through drive shafts ?
Sort of a mechanical “ blackfly” idea?
8,051
Read about the BeetleMaster.
Andy_RR
Sep 29, 2009
234
Melbourne, Australia
The Death of Pelican 16 is a great documentary about how a multi engined aircraft can take you to inhospitable places before a loss of multiple engines takes you down
7,295
FWIW, I have always been fascinated by small, low-power multi-engine aircraft. A great example is the 1925 Daimler-Klemm L21, originally conceived for a light aircraft competition in which the lowest power category was 40 hp. Klemm's previous L20 design had only a 20 hp engine. So...
daimler-klemm-l21-rohbau_.jpgdaimler-klemm-l21-d-622-speichenrc3a4der.jpg2-klemm-daimler-l21-d-622-deutscher-rundflug-1925-mit-2-motoren-daimler-konzernarchiv-u4424.jpgdaimler-klemm-l21-d-622.jpg
I have often daydreamed about something like this but with an enclosed, side-by-side, two-seat cockpit and pair of basic direct-drive VW conversions on the wings, perhaps with some sort of brake system *if* it proved necessary (a relatively short VW prop might not be able to windmill in any case). A pair of industrial V-twin engines with Ace redrives might also be worth considering.
The key here is to keep the weight and wing area down in microlight or even motorglider territory to allow for adequate climb rate and angle on low power, top speed be damned. More info in the links below (I used Google Translate for the German.)
Daimler-Klemm L 21 (Google Translate)
Too many planes, not enough time....
David Lewis
Oct 4, 2018
25
Longwood FL
Ford put a higher hp engine on the nose on some models than the wings... because you needed more hp in the advent of an outboard engine failure to compensate for the drag created by yawing the aircraft...
You're correct. There was not a 1/3 + 1/3 + 1/3 split. The nose (main) engine alone was just enough to keep limping along if you open the throttle. I believe if a wing-mounted (auxiliary) engine fails, the pilot shuts down the other auxiliary engine, and doesn't have to deal with asymmetric thrust.
