An argument in favor of multi-engine design
ToddK
Jan 13, 2016
299
The Real Texas
It seems to me that something along the lines of the Dornier Do 335 Pfeil would be the simplest. Dornier Do 335 Pfeil.jpg
Put a VW in the front, and Rotax or MZ in the back.
DangerZone
Sep 5, 2011
2,110
Zagreb HR
It seems to me that something along the lines of the Dornier Do 335 Pfeil would be the simplest. View attachment 56021
There's also the Bugatti 100 replica, similar design but the concept has twin engines turning one prop.
This twin engine is interesting, if one could build it as a pusher only aircraft. Kind of like a stretched version of the BD-5.
Steve C
Oct 6, 2008
78
Lodi, CA
From what I read, it sounded like it could not survive full power so they accepted a reduced setting as 100% and gambled on it staying together for one last flight.
CharlieN
Sep 7, 2018
38
Vermont USA
It is somewhat frustrating since 400hp from a turbocharged Hayabusa is not into any unreliable range.
I do not know if the clutch that failed was the factory clutch or an overunning clutch in the aircraft gearbox, but the Hayabusa engine and transmission will withstand power in the 900hp range, proven at the Daytona shootout recently. This obviously is not with all factory internals but I run a 380hp Busa motor in a road course car with an all stock internal engine. That includes a stock clutch. No issues.
Pilot-34
Apr 7, 2020
354
How much do wing mounted engines increase drag ?
What improvement is a engine buried in the wing with only the propeller and spinner exposed compared to the usually seen engine mounted in front of the wing?
7,228
Wing mounted engines could possibly reduce the overall drag of the airplane under some conditions, compared to the DO-335 layout. If the engine nacelle and wing fairings are done right, it can be pretty clean. See DH-98 Mosquito for example.
Pilot-34
Apr 7, 2020
354
I agree that is one of the cleanest installations I’ve seen. Yet that still looks like almost the same amount of drag that you would get building two more airplane fuselages and hanging them on the wing.
Chilton
Jun 28, 2014
95
Arusha
On the de Havilland theme, look at the installation on the DH 91 Albatross, the V12 Gipsy engine blends right into the wing.
Pilot-34
Apr 7, 2020
354
Has there ever been a airplane with a fuselage mounted engine driving two or more wing mounted propellers through drive shafts ?
Sort of a mechanical “ blackfly” idea?
  • Like
Reactions: dog
Doggzilla
Jun 2, 2013
2,287
Everywhere USA
With modern hybrids you could move the cockpit up for much better view, and have the engines mounted rear. Would greatly improve access to the cockpit as well, as you could just have a side door.
Doggzilla
Jun 2, 2013
2,287
Everywhere USA
Yes, I believe some designs after WWI. I’m thinking some sort of seaplane but I’m not entirely sure. I also know there was some huge multi engine thing that ran two props per engine using belts.
mcrae0104
Oct 27, 2009
3,260
Edit--oops, I see the question was about a single engine driving multiple props.
