The SKY-RAY design features -
Wire braced without needing a kingpost, and without taking the wires to the axles so you can still have large suspension travel.
The need for good separation between the top and bottom wire connection points encourages a reasonably deep fuselage which suits the 'expanding size of the population' and means we will have 'man-sized' aircraft.
Wire bracing provides for two support points along the spars (rather than one if it had struts) for much stiffer/lighter structure.
Pilot is seated on the CG so no need to ballast for differing pilot weights.
Pilot protection is good. It is not an 'arrival machine' where the pilot is the first thing to arrive at the destination (particularly if it is a crash site...) and that is good for all and particularly the less experienced flyers.
Excellent rollover protection.
Design is well suited to pop rivetted industrial grade square tube (radiused corner) and gusset construction for the fuselage and tubular front/rear spar wing with tubular rivetted built-up ribs. Internal compression struts and internal wire drag/anti-drag bracing. Stits/polyester sewn bag covering, heat shrunk with dope etc...
Could be tailwheel or nosewheel by reversing the wishbone of the maingear (side for side swap), yes the wheels are shown too far forward in the sketch of course.
No need for a lower cowling, run the centre and lower longerons all the way forward to the spinner and truss them all together to form an engine bed. Add 'power bulges' each side if it's an inline twin 2 stroke, one side shrouds the carbys and the other side covers the exhaust bend, put the muffler under the engine to fully conceal the ugly thing...
One person rigging, carry-on-your-back/drag the wing up to the side of the fuse, leave wingtip on ground, connect spars and flying wires, prop-up the wingtip, connect the landing wires with an overcentre snap toggle which tensions them, apply safety pin, connect controls, done.
Simple design to incorporate aerodynamic balance on all control surfaces, made from bent tubing. Convenient place to install minimum weight mass balancers.
Using tapered control surfaces is a neat way to provide attractive shape to a rectangular wing.
No wing root fairing is needed and the 'cut-away' in the inboard flap area provides easy access for ingress/egress via the rear spar.
Open or closed cockpit simply by adding a wrapover from windshield to turtledeck, wrapper can be carried in fuselage baggage area behind pilot.
Large control surfaces for good low speed handling and controllability in turbulence/crosswinds etc
Go for it HBAers, tear it apart, improve it, discard it, hate it, love it - it's just a conversation starter if you like
