1936 Dart Pup (aka Dunstable Dart)
Discussion in 'Hangar Flying' started by cluttonfred, Mar 5, 2019.
  1. Mar 5, 2019 #1
    6,351
    2,208
    For some reason I find this pusher parasol layout very appealing, maybe for a modern, VW-powered microlight at 315 kg/694 lb gross weight?
    dart_pup.jpg 1133-1.jpg Dart_Pup_photo_Le_Pontentiel_AĆ©rien_Mondial_1936.jpg
    I think the "pilot" in the RC model needs a cushion to sit on.
  2. Mar 5, 2019 #2
    3,550
    1,527
    I'm not usually a fan of parasols, but I like that one.
    Great visibility. I'm not sure about the function of the wing sweep, but it looks good.
  3. Mar 5, 2019 #3
    6,351
    2,208
    I suspect that the wing sweep was required by the combination of a relatively heavy engine and a relatively light pilot as well as clearing the prop. Note the trailing edge cut out. While I prefer four-strokes, this might be a good application for a modern tandem paramotor 35-40 hp two-stroke engine. The light engine and smallish prop should allow you to reduce the sweep a little and get rid of the cut out for the prop.
    Here are a couple of contemporary articles about the original Dunstable Dart from FLIGHT magazine.
  4. Mar 5, 2019 #4
    Riggerrob
    Riggerrob
    Riggerrob
    Sep 9, 2014
    1,123
    309
    Canada
    As two articles state, swept back wings help roll and yaw stability.
    They also state that sweep back helps balance the airplane. Many other single-engined, pusher airplanes struggle with balance (e.g. Republic Seabee light amphibian). One version of the Spencer Aircar (plans-built successor to Seabee) has slightly swept wings for balance.
  5. Mar 5, 2019 #5
    6,351
    2,208
    Yup, the sweep can be a real benefit. This actually reminds me a bit of David Thurston's clearly amphibian-influenced landplane designs in his books Design for Flying and Design for Safety. Blend the Dart Pup with the Thurston-designed Patchen Explorer (below) and you actually have a very modern looking little plane.
