I have been poking around the internet looking for a new motor for my plane, not because i don't like vw 2180 but I wanted a more powerful and modern engine. I like the output of the rotax 912 but the cost is to high, same for jabiru, i could upgrade my 2180 but it would still fall short of some of the improvements I want, I was going to install a suzuki g13b but I would have to sell my 2180 to buy it. The sonerai really has a small window for weight and power requirements witch makes finding an engine a bit of a problem if you really do not want to mess with the original frame design. My intent was to find a motor that would not weigh more then 180# and would produce at least 100hp, in doing so I wouldn't take away from useful load or treed outside of design limits into the world of time consuming mods. I didn't want to modify my tail surfaces, add weight, or anything that would add time to the engine swap. I wanted fuel injection, electronic ignition control, dry sump, a modern all aluminum power plant with lots of power to preform inverted flight in, and i wanted it to be cheap of course. SO i stumbled across a post on a rotary forum of a guy who was modding yamaha snowmobile engines to run gyro copters and found the power plant i was looking for, the yamaha genesis 1200cc 4stroke. The genesis comes in at 145# wet weight with 120 hp that is without the psru but does include the starter, alternator, and engine accessories. They have manufactured a mounting/adapter plate to link a rotax c gearbox to the genesis motor, which is great since the rotax c box is tried and true and readily available. I think the entire package sounds great for our aircraft and the best part of all the first prototypes only cost 4000 dollars between the engine and all the extra parts!!! I am going to start emailing the guy that designed the first motor and get rolling on this swap. I think this new motor will put the sonerai in an entire new performance class even with full gross, and its cheaper then vw! Finally a high power engine with acro possibilities at a cheap price.
The down side is I do not think it will fit inside the stock cowling and i will be forced to change the lines of the nose. I really do love the look of the sonerai with but we will see how this all turns out, maybe it will have a nose more like a spitfire. Also i wont have dual ignition until i mod that into the engine as well, their will be coolant and plumbing issues to work out, engine mount brackets, and countless other issues to work out. Feel free to give me your input and thoughts on this project, I will try to post more info on this subject as it comes up. Also their maybe a 2180 cc vw engine up for sale with a slick mag, electric secondary, ellison throttle body, starter, alt, and prop: basically a full engine package if i find this Yamaha motor to be worth the hassle after more research.
