Oh, if people INSIST:View attachment 124354
Hehe, that’s not a P-39 that’s a pre-WWII Bell Model 3 interceptor, progenitor of both the Airacobra and the XP-77.
And with the liquid cooled engine you could even put the radiator under that scoop aft of the canopy. The exhausts from the front mounted engine will have to be hidden somewhere.Maybe use a 100 hp Aeromomentum AM13 or other small Suzuki conversion? I’ve even got my color scheme all picked out.
I think I'd rather fiddle with the wing and the tail volume to move the CG. Maybe a little more chord towards the aft end, a little change in stabilizer size, a little different sweep...lots of ways to move CG around without getting away from the general proportions of the original. Still, it's a replica, so a certain amount of liberty has to be figured in.Cheat the cockpit a little aft and the wing a little forward and you’re all good.
That doesn’t really define aerobatic capability. Almost any airplane can do that with the right pilot.but it needs to be able to do a barrel roll or what's the point?
Works for me, as long as a nice victory roll can be had, it's all good. If I'm mock-strafing freight trains, that doesn't require aerobatic capabilities either.That doesn’t really define aerobatic capability. Almost any airplane can do that with the right pilot.
Yeah, maybe the inverted oil setup and fuel pumps can help with the CG issues! I do need to reckon on the right camera setup to capture the glorious exploits!Gotta pull loops and immelmans and split S-s or it's just not worth it![]()
Are you reading my mind? I thought about using a Corvair conversion mounted in the original spot, using the wing root ducting for the cylinder and oil cooler air flow. Still have to figure out the drive shaft vibe dampening. And the redrive, though I shouldn't need any reduction with the Corvair.If one insists on the rear / mid mounted engine, look again at the cutaway drawing. The original P-39 (and P-63) had the radiator cooling ducts mounted at the roots of the wings. Using this, one could mount an opposed air cooled engine low and behind the pilot and duct the cooling air through the wing spars and back to the engine. OR a Subaru conversion or even Rotax opposed 4 stroke could be used. Dennis
