Ultralight Instrumentation / Transponder / Radio
Aviatrix
Apr 19, 2005
135
Phoenix, Arizona
Hey, all
Finally starting real work on the Affordaplane,
and was wanting some tips on Instrumentation and such.
I plan on the following instruments:
Altimeter
Compass
Bank/Horizon
Fuel
Volt/Ammeter
Tachometer
Airspeed
I may also tap into the 440 for Oil Pressure, not 100% certain.
I'm assuming I'll need some sort of a radio in order to talk to the tower if I want to fly out of any sort of a real airport.
I received my Aircraft Spruce catalog last week and found some nice pricing on instrumentation,
so I'm not terribly concerned about having to add a few more if needed.
Any thoughts on my list or tips on what model of radio would serve my needs?
I'd prefer one that I could use headphones and mic inside my helmet with.
Thanks in advance
Aviatrix
Apr 19, 2005
135
Phoenix, Arizona
I'd also appreciate any tips on instrumentation choices.
Do I have enough? Too many? Etc.
Is there a particular brand than anyone is partial to?
I don't want digital units, nor are multi-Function electronic displays a consideration.
Thanks
Rhino
Apr 8, 2004
771
SW Ohio
Originally posted by Aviatrix
.......nor are multi-Function electronic displays a consideration.
Yeah, that would be a hoot on an Affordaplane. Might as well get an autopilot, flight management computer and a TCAS system too. :gig:
Aviatrix
Apr 19, 2005
135
Phoenix, Arizona
And actually what I meant by multi function display are those spiffy Horizon, Altimeter, Tach, "all in one" units.
Not the 1 sq ft. LCD Panels that look like they belong in an F-22. ;-)
wally
Mar 31, 2004
928
southwest TN.
I a thinking that the Kawasaki 440 is a two stroke twin. If it is what I remember, it does not have an oil pump. If it does have an oil pump, a lot of guys who fly two-strokes will strongly suggest you remove it and mix the oil with the gas. You will have one less thing that can go wrong and make the noise stop. Most ultralights don't have much of a glide ratio when the noise stops.
Premix wally
Firstscout
Mar 14, 2007
33
Western Washington
Here is the acronym for Day VFR required instruments
Some don't apply like the oil pressure and landing gear position indicator. hope this helps..
having looked at the plans for the affordaplane I wouldn't recommend flying it into any towered airport.
good luck with your project
my 2cents
[SIZE=+3]T[/SIZE][SIZE=+3]- Tachometer
O - Oil pressure gauge
M - Manifold pressure gauge
A - Altimeter
T - Temperature gauge for each liquid cooled engine
O - Oil temperature gauge
[/SIZE]
[SIZE=+3]F - Fuel gauge
L - Landing gear position indicator
A - Airspeed indicator
M - Magnetic direction indicator (compass)
E - ELT
S - Seatbelts
[/SIZE]
