The design-a-plane thread
Discussion in 'The light stuff area' started by Autodidact, May 22, 2014.
  1. Jun 2, 2014 #221
    Brian Clayton
    Brian Clayton
    Brian Clayton
    Dec 7, 2012
    1,042
    530
    Ivey, Ga and Centerville,Tn
    The generator engines I have repaired, the ones using splash tube only for the top end, generally wear out the pushrods between 500-1000 hrs. Wear out like valves wont move enough to let the engine crank.... We have a couple of mowers that have the larger v twin engines with hyd lifters and oil thru the pushrods. Had to put head gaskets on one the other day, didnt see any appreciable wear on the valvetrain.
  2. Jun 2, 2014 #222
    12,494
    2,525
    What V-twin has hydraulic lifters?
  3. Jun 2, 2014 #223
    Brian Clayton
    Brian Clayton
    Brian Clayton
    Dec 7, 2012
    1,042
    530
    A kohler does for sure. 38 or so hp if I remember right.
  4. Jun 2, 2014 #224
    12,494
    2,525
    I haven't looked at Kohler much, I think they are more heavy duty than needed ( heavy).
    Because a good generator needs to run for hundreds or thousands of hours without much maintenance.
    For aviation, I don't mind adjusting valves every so often. At average 20 hours a year of flight time, wear isn't a big concern.
    akwrencher likes this.
  5. Mar 27, 2015 #225
    TerryM76
    TerryM76
    TerryM76
    Sep 8, 2012
    518
    193
    Tempe, AZ
    Did you get a response for this question regarding the plywood? I have a few sheets of the Midwest Plywood that I m intending for RC plane construction but I have not evaluated it for using in full-size. Just considering it might be useful in built up wing rib construction for gussets. I have started looking at wood for a Wagabond project and was rather surprised at how much wood has gone up in price over the years. Anyone have suggestions how to scientifically test the wood to determine if it would be adequate for homebuilt aircraft applications?
  6. Mar 27, 2015 #226
    Richard6
    Richard6
    Richard6
    Aug 14, 2010
    681
    77
    Plymouth, MN USA
    I operate a small engine repair shop out of my garage and have come across several interesting engine issues. One of them being a OHV BS engine that blew a head gasket. The problem was that there was a large gap between the head bolts in the area where the push-rods came up thru the head.
    After repairing the engine, replace gasket using gasket sealing compound, I sent photo to BS pointing out the problem. Got a e-mail back saying that it is not a problem. I guess that they did not want to accept any claims of poor design.
    Richard
  7. Mar 27, 2015 #227
    Autodidact
    Autodidact
    Autodidact
    Oct 21, 2009
    4,513
    799
    Oklahoma
    I've sent the supplier to the hobby shops (Midwest Products) an email; in view of most peoples abject fear of lawsuits, it should be an interestingly worded reply if I get one....
    Logically though, if I were Midwest Products, and knowing that supplying hobby shops is a relatively large volume business (compared to homebuilding - a hobby shop in every medium and up size city in America), I would order in bulk from the Finnish birch manufacturers and saw it up for a profit based on volume sales?
  8. Mar 28, 2015 #228
    TerryM76
    TerryM76
    TerryM76
    Sep 8, 2012
    518
    193
    Tempe, AZ
    It would at least be interesting to hear the source of their supplier. With that knowledge it might be possible to learn more about the process used in manufacturing. I plan on doing some destructive testing when I get all of my materials together. I certainly would like to know how others have taken that approach and what methods of testing they used.
  9. Dec 9, 2015 #229
    airplaneAddict
    airplaneAddict
    airplaneAddict
    Nov 20, 2013
    60
    19
    Kewanna, IN USA
    I just built a Poorboy, and don't want to stop building.
    Here are a few of my ideas
    MATO
    spaschke likes this.
