The 'daydreamers' thread...post your craziest designs and concepts here
Discussion in 'Hangar Flying' started by Floydr92, Apr 12, 2016.
  1. Apr 30, 2016 #101
    Swampyankee
    Swampyankee
    Swampyankee
    Dec 25, 2015
    1,404
    360
    Earth USA East Coast
    I think that a tilt-wing or a tilt-rotor could be viable homebuilt projects, with a lot of ifs, not excluding somebody willing to design and built controllable pitch propellers with flapping and (probably) lead-lag hinges, either real ones or virtual ones (hingeless rotors have a soft-in-bending section in place of mechanical hinge). (Check out the VTOL Wheel for more fun homebuilding ideas; I rather like this one: 40.jpg ). Once one leaves out helicopters and compound helicopters, VTOL becomes hard, and for many of them, I'd want to have a zero-zero ejection seat, not just a ballistic parachute.
    Neither the tilt-wing nor tilt-rotor configuration is particularly easy, and both have disadvantages. I suspect (which means that I've not done a full-blown analysis) that the structural issues of a tilt-rotor are easier (for one thing, the wing doesn't need to move) but the aerodynamic ones of the tilt-wing are easier; it ends up being a trade study. Bell Helicopter had a lot of experience with tilt-rotors, so the V-22 was a tilt-rotor; had Hiller or LTV been major players, the JVX may have been a tilt-wing.
    Bluntly, I would not trust my life in any kind of tail-sitter, especially one powered by a piston engine. Give me a robust, well-proven gas turbine engine any day!
  2. Apr 30, 2016 #102
    RPM314
    RPM314
    RPM314
    Mar 27, 2015
    724
    302
    NY, USA
    There's a class of aircraft in RC called a "hotliner", which is basically what happens when you take a competition sailplane and put a motor on it more typically found on pylon racers, with a folding prop. They're built for energy retention at high speeds, vertical climbouts, etc. I highly recommend Youtubing it.
    I know of course that there are power loading limits as you scale up, but I wonder how far you could get at general aviation scale, using the peculiarity that composite wings get lighter as AR goes up. Maybe a 2 stroke to get in as much HP as possible, and easier starts/stops?
  3. May 18, 2016 #103
    delta
    delta
    delta
    May 27, 2011
    1,978
    200
    Brookside Utah
    This one stems from pedal powered crafts I've seen turning a very large slow turning prop. Decavitator and Aug. 23, 1977: Pedal-Powered Gossamer Condor Flies Into Record Books | WIRED I figure a 20hp Briggs with a massive reduction would keep it in the air longer than I could. An electric motor on the rear wheels for ground operation would get me to a restaurant or service station. If I could keep the weight down, I'm sure the top speed would not exceed part 103. Using bicycle wheels instead of motorcycle wheels might help it be street legal but a reverse trike configuration would be easy enough. Air cylinder/shocks, would adjust the ground angle of attack to facilitate take off or hugging the road. The thing would be so quiet the park service might not even hear you when you buzz the Grand Canyon.
    Floydr92 likes this.
  4. May 24, 2016 #104
    delta
    delta
    delta
    May 27, 2011
    1,978
    200
    Brookside Utah
    I amuse myself sometimes...
    Floydr92 and Chris In Marshfield like this.
  5. May 27, 2016 #105
    2,972
    1,672
    This one comes from an older sketchbook but I don't think I've posted it here before. The idea started with the thought of jazzing up the basic concept of the Affordaplane and one thing led to another, finally settling on the Afforda-Stang:
    [​IMG]
    Don't dig too deep into it, it's only a concept.
  6. May 27, 2016 #106
    Floydr92
    Floydr92
    Floydr92
    Aug 13, 2013
    357
    119
    Scotland
    Nice sketching skills, wish i could do that. I can do good engineering drawings, but i find sketching difficult. Frustrating with so many 'napkin sketches' in my head. Haha. So, a napkin sketch for me is usually a computer rendering of some kind. Usually x-plane comes first.
  7. May 28, 2016 #107
    bifft
    bifft
    bifft
    Apr 17, 2011
    245
    90
    Utah
    Since this thread is still alive, thought of another impractical one. "The ellipse" Elliptical wing, with elliptical polyhedral. Elliptical full flying ruddervators. Would be way too hard to build, and how would you hinge any control surfaces on the wing? Would look kinda pretty.
  8. May 28, 2016 #108
    delta
    delta
    delta
    May 27, 2011
    1,978
    200
    Brookside Utah
    A ring wing would be nice structurally and aerodynamically (maybe), but talk about a nightmare to build...
      File size:
      18.2 KB
      54
      File size:
      15.7 KB
      48
      File size:
      22.8 KB
      48
    nucleus likes this.
  9. May 28, 2016 #109
    2,972
    1,672
    Thanks Floyd, that's the result of spendingyears doodling. I always found it was too hard to pull out a laptop and design in X-plane during math class...
    Battler Britton and Floydr92 like this.
  10. May 28, 2016 #110
    Twodeaddogs
    Twodeaddogs
    Twodeaddogs
    Jan 18, 2009
    838
    238
    @delta, they look like aircraft from Dasterdly and Muttley:gig:
  11. May 29, 2016 #111
    deskpilot
    deskpilot
    deskpilot
    Jun 30, 2009
    1,100
    185
    I've often wondered if this ring wing ever flew
    nucleus likes this.
  12. May 29, 2016 #112
    delta
    delta
    delta
    May 27, 2011
    1,978
    200
    Brookside Utah
    I saw that one at Oshkosh I believe in 2004. I didn't see it fly and haven't heard a word about it since. I didn't look real close at the time, but I'm also curious now how he hinged the curved control surfaces. The F4U Corsair flap system may contain some ideas in that regard, but it's probably not very simple or light.
  13. May 29, 2016 #113
    Swampyankee
    Swampyankee
    Swampyankee
    Dec 25, 2015
    1,404
    360
    I've seen some proposals for ring-wing airliners, but, like a lot of these designs, there are a lot of practical problems, including where to put things like landing gear and fuel.
  14. May 29, 2016 #114
    delta
    delta
    delta
    May 27, 2011
    1,978
    200
    Brookside Utah
    Here's another one from my file of dreams...
      File size:
      18.1 KB
      34
      File size:
      14.6 KB
      28
      File size:
      17.3 KB
      28
      File size:
      11.6 KB
      33
      File size:
      22.5 KB
      31
    nestofdragons and nucleus like this.
  15. May 30, 2016 #115
    deskpilot
    deskpilot
    deskpilot
    Jun 30, 2009
    1,100
    185
    Delta, I like your style. What cad program are you using?
  16. Jun 1, 2016 #116
    delta
    delta
    delta
    May 27, 2011
    1,978
    200
    Brookside Utah
    Thanks Doug. It's all Rhino's fault. I got a students edition quite awhile back off ebay and it's been way to much fun.
  17. Jun 2, 2016 #117
    Giggi
    Giggi
    Giggi
    Jun 10, 2014
    113
    62
    New Hampshire, USA
    Have you ever modeled something with a straight line in it? :gig:
  18. Jun 2, 2016 #118
    delta
    delta
    delta
    May 27, 2011
    1,978
    200
    Brookside Utah
    Most of the RC models I've made were straight as an arrow, because they were made with CF arrows and golf club shafts.:gig:
  19. Jul 20, 2016 #119
    delta
    delta
    delta
    May 27, 2011
    1,978
    200
    Brookside Utah
    The "What replica warbird would you like to see" poll didn't allow the p-38 because it had two engines... not fair... I would love to see a reasonable representation of a p-38 in the works. The configuration is sound, and with a couple of turbocharged vw's it'd scoot pretty good at altitude.
    I had to add a couple of delta delta wings just for drill.
      File size:
      20.3 KB
      26
      File size:
      12.7 KB
      26
      File size:
      15.6 KB
      23
      File size:
      14.9 KB
      26
      File size:
      21.8 KB
      27
      File size:
      17.3 KB
      26
      File size:
      14.1 KB
      26
      File size:
      15.2 KB
      26
      File size:
      13.9 KB
      27
      File size:
      16.4 KB
      19
  20. Jul 20, 2016 #120
    10,029
    6,777
    IIRC, it had control surfaces only on the strut/wing that supported the back half of the ring-shaped wing.
