The answer to Gorilla glue ???
Discussion in 'Wood Construction' started by Tarkus, Jul 10, 2015.
  1. Aug 17, 2019 #121
    11,694
    2,198
    I was reading the Sport Aviation archives from the 50’S. They used casein (milk) glue. It said the glue shear strength was 250 psi., as I recall. So if that casein glue was good enough then, another modern glue that exceeds 250 psi shear might also be adequate, even if not as strong as epoxy in some ways. The joints need to designed with enough glue area in any case.
  2. Aug 17, 2019 #122
    9,353
    6,130
    Aviat (Pitts) specified Weldwood Plastic Resin for the ribs in the certificated S-1S.
    I would be very surprised to learn that any of the experimental Pitts / Wolf variants (Sean Tucker, et al) use anything other than T88.
  3. Aug 17, 2019 #123
    John wadman
    John wadman
    John wadman
    May 27, 2019
    183
    204
    i tested joints with weldwood plastic resin when i built my first wood and fabric plane and it didnt test well. i used WEST system on that plane. i still have a gallon tub of it on my shelf. im temptd to test it again after i do my failure tests with the epoxy im currently using
  4. Aug 17, 2019 #124
    11,444
    3,182
    If you can’t glue Weldwood in 100 deg heat with a ton of pressure, it will fail. Glued Cold equals bad joint
  5. Aug 17, 2019 #125
    9,353
    6,130
    I’m willing to bet that there are over 1,000 propellers flying on HBA and ultralights that are being held together with Weldwood Plastic Resin, not to mention spars.
  6. Aug 17, 2019 #126
    11,444
    3,182
    Culver uses Weldwood but they cure it in an oven in the clamps. Someone working in a cold basement in Minnesota using the stuff like Elmer’s is why it has gained a reputation. It was promoted as easy. There are a lot of restoration people who know how to use it that would prefer it. It’s just got a rap that it’s not going to shake.
  7. Aug 18, 2019 #127
    John wadman
    John wadman
    John wadman
    May 27, 2019
    183
    204
    I've got that entire gallon tub of it on the shelf in the shop. I tested it in the S. Florida heat in a non-insulated metal building with no airco! It was pretty warm. And I did clamp it. But now I'm tempted to test it again just for the heck of it. I'll do my destruction tests on the epoxy glued sticks and then maybe recreate the exact same tests with sticks laminated from the Weldwood. I think I will. It'll be awhile but when I do I'll post the results on the wooden airplanes part of this site. Maybe I screwed up but I can speaka and reada di english real good (real well) and the instructions were pretty simple to follow.
    akwrencher likes this.
  8. Aug 18, 2019 #128
    11,444
    3,182
    I think the stuff can spoil too. That is where testing starts being not fun. It sometimes costs a lot to just say no. Test $200 worth of glue to buy $200 worth of glue.
  9. Aug 18, 2019 #129
    John wadman
    John wadman
    John wadman
    May 27, 2019
    183
    204
    TFF, I just posted the preliminary results of my wood tests on my builders log site under Ragwing RW 19/20 wood and fabric Storch. Not convinced they are accurate though. Got some more testing to do . I’ll throw in some Weldwood samples too.
  10. Aug 18, 2019 #130
    Doran Jaffas
    Doran Jaffas
    Doran Jaffas
    Jun 25, 2019
    15
    1
  11. Aug 18, 2019 #131
    Doran Jaffas
    Doran Jaffas
    Doran Jaffas
    Jun 25, 2019
    15
    1
    Resourcinol glue was used in aircraft for years. The glue must be properly mixed and clamped but produces an excellent joint. I used it on a propeller I made very successfully.
    I am old school but I would be very reluctant to use any glue not specifically tested for aircraft use. Especially when looking at the long term viability.
  12. Aug 18, 2019 #132
    11,694
    2,198
    Bud Evans (VP-1) did a large test of Recorcinol, Weldwood Plastic resin and Aerolite glue.
    He ranked Aerolite best, Weldwood was next (used for Fly Baby) and he said Recorcinol failed on half the bond.
  13. Aug 18, 2019 #133
    9,353
    6,130
    Anyone have any experience with FPL-16A? It was reputed to be very good.
  14. Aug 19, 2019 #134
    mcrae0104
    mcrae0104
    mcrae0104
    Oct 27, 2009
    2,939
    1,941
    BDU, BJC
    Was this in Sport Aviation? I like Aerolite (other than perhaps the concerns from the arguably-nanny-state Australian authorities--no offense intended to my friends down under) but resorcinol seemed to be this troglodyte's last best hope. And now you burst my balloon. :)
  15. Aug 19, 2019 #135
    mcrae0104
    mcrae0104
    mcrae0104
    Oct 27, 2009
    2,939
    1,941
    BDU, BJC
    Do you have the EAA wood construction book?
  16. Aug 19, 2019 #136
    9,353
    6,130
    No.
  17. Aug 19, 2019 #137
    11,694
    2,198
    Yes, in Sport Aviation 1965 or 66. I just read it yesterday but the search function doesn't work so I couldn't find it.
    Now reading 1969 today. There was another article on FPL-16a . But they didn't mention high temps then.
    mcrae0104 likes this.
  18. Aug 19, 2019 #138
    mcrae0104
    mcrae0104
    mcrae0104
    Oct 27, 2009
    2,939
    1,941
    BDU, BJC
    There is a bit on FPL-16A. I will take a look when I have it handy.
    BJC likes this.
  19. Aug 19, 2019 #139
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,390
    246
    Sydney
    As a Aussie,
    What was the concern about Aerolite Glue?
    Don't worry, we rarely take offence.
    Our Nanny state tends to be over the top sometimes, unless it involves big bussiness. Then it tends to be open season to do anything.
  20. Aug 19, 2019 #140
    Mcmark
    Mcmark
    Mcmark
    Sep 24, 2013
    262
    123
    Owings, MD
    Griggs Aircraft builds and sells Wolf Aircraft Products. They are constructed with T-88. Chris swears by it. His ASllS that was in Sport Aviation a couple months back had its wings also done in it.
