Alright, better switch to English so that others will be able to help you out.
Knowing how to weld is indeed a great advantage, and you have another one: your age. And since you're living on a tiny island it has to be amphibian, period. However welding won't be much useful if you want to go for a wood construction, the only time you'll weld is probably when making the engine mount.
Another thing is to choose something which has already been built with floats. You could theoretically mount floats on almost anything, but you need to re-calculate the W&B, drag, how much power you need, engine, tanks, etc. It's not a small modification.
The Zenith 701 and many of its derivatives can be made with floats successfully, as many have already done. That's a proven design. It's all metal though, not wood.
The delta trikes can use floats as well, and that's probably the simplest construction there is. But you have to buy the wing, it requires special tools to stitch the sail.
Consider how difficult it is to get materials and tools, even though it's a tiny island it's still part of Italy, not some God-forsaken place. You also need a place for building it, not too big but not too small either.
Lots of things to consider, but you are doing the right steps. Don't get discouraged, we're here to help.
