Stress Analysis, Structural Design
Andrew_J
Aug 30, 2013
7
Kiev, Ukraine
Greetings to everyone:
I provide engineering assistance in the following areas:
  • Structural Design of aircraft parts.
  • Stress Analysis of aircraft parts.
Below are examples of projects which have successfully been accomplished online. Aircrafts in those projects have already been constructed, and now they browse the skies.
Light Sport Aircraft A22LS (www.aeroprakt.kiev.ua) Landing gear Main Leg Designing and Stress Analysis
АИ-10 (Ikar Ai-10 Ikar - Wikipedia, the free encyclopedia) New metal Tale Boom designing.
I work as a senior engineer at an aerospaceengineering company (www.progresstech.ru) for more than five years. Ourcompany mostly designs commercial aircrafts, but Ultra Light, Light Sport, and experimental aircrafts are of my great interest.
I will be pleased to provide my assistance to you.
Thankyou.
AndrewJorjishvili.
Andrew_J
Aug 30, 2013
7
Kiev, Ukraine
When I estimate the job price I use 20$/hour fee rate. Below is very simple description of the Light Aircraft Landing Gear front Leg Stress Analysis project. Within the scope of this project I have accomplished the following:
  • Calculated the Landing Gear Front Leg Loads in accordance with the FAR23 requirements
  • Created FE model of the Landing Gear Front Leg
  • Performed stress Analysis of Landing Gear Front Leg components.
The static stress report is written on 109 in *.xls format pages and has FE model *.db file attached.It took me 100 hours.
berridos
Oct 10, 2009
1,129
madrid
very reasonable. For sure you will get some clients over here. Maybe me but in half a year or more.
turkeykiller
Aug 6, 2013
Shenyang
Andrew,I think you did a good job!Same as you I worked 5 years too in aircraft structural engineering.But I can't do any stress analysis.So there is a long way for me to go.Good luck!
cheapracer
Sep 8, 2013
6,294
Australian
Just to be clear, do you charge $20 per hour on the job itself?
...or is that just the fee for quoting the job and if so, what is the rate for the jobbing?
berridos
Oct 10, 2009
1,129
madrid
Have you got cnc machining capabilities to include the finished part as part of the job?
Andrew_J
Aug 30, 2013
7
Kiev, Ukraine
I haveCNC module in CATIA. I also maintain cooperation with CNC manufacturing firms.But the price of a single part might be quite high. Mailing metal parts couldbe expensive too.
berridos
Oct 10, 2009
1,129
madrid
I am currently thinking on a gimball that will quench the landing gear. As I end my holidays I will scan the piece and show a picture. Pazmany offers two rotating landing gear solutions. One would imply welding and metal and the other one would allow for a carbon composite leg.
addicted2climbing
Jan 27, 2012
1,168
Glendale, CA
Andrew,
I will be very interested and have a project I plan to get to in October. I own the rights to a few plans built aircraft and want to redesign the 4130 fuselage for aluminum tube and gusset similar to how the Graham Lee or Baslee WW1 aircraft are done. I have the fuselage drawn in Solidworks but its not finished yet. Would this be doable? Aircraft is here: www.cloudbaseaviation.com
I could supply the plans and the solidworks file? I see you use Catia, any chance you also have Solidworks so there is no conversion?
Current fuselage
Looking for something like this:
addicted2climbing
Jan 27, 2012
1,168
Glendale, CA
Andrew,
Current fuselage
Im mostly concerned with the cabane mounting. The front one (in Green) would likely be one continuous bent tube from lower longeron to the wing attach point. The rear likely the same but would require modifying the truss tubes or leave as is with the added vertical between the existing truss tubes.
poormansairforce
Mar 28, 2017
1,100
Just an Ohioan
Andrew hasn't been around since 2013....
