Slot in wing for pusher prop???
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by Aerowerx, Jul 16, 2019.
  1. Jul 16, 2019 #1
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,266
    1,469
    Marion, Ohio
    There are a number of RC tailless planes with a slot in the wing for the pusher prop.
    Other than the likelihood of increased noise from the prop blast hitting the trailing edge of the wing, what would the consequences be of doing this on a full size wing?
  2. Jul 16, 2019 #2
    13,152
    5,063
    Any gap in a wing can cause a loss of lift and increase in drag due to flow from the higher pressure lower side to the lower pressure upper side.
    wsimpso1 likes this.
  3. Jul 16, 2019 #3
    Steve C
    Steve C
    Steve C
    Oct 6, 2008
    59
    36
    Lodi, CA
    Really loud and not very good for prop efficiency. Potentially damaging to the prop as well since it could cause resonance issues.
  4. Jul 16, 2019 #4
    7,323
    2,106
    Look at how mechanical sirens are made...
    wsimpso1 and Voidhawk9 like this.
  5. Jul 16, 2019 #5
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,266
    1,469
    Marion, Ohio
    My reason for asking this is that it would allow the engine to be placed in a more suitable location with respect to the CG. If the engine was placed at the trailing edge of the wing, then you will need a lot of weight towards the front to get the desired CG location.
    Or change the sweep to move the neutral point farther back. But there is a limit to this, as the pilot has to sit in front somewhere, which moves the CG again.
    The ideal situation would be to have the pilot (and passenger, fuel, and luggage) at the empty CG location.
    I read somewhere (Bengelis??) about the minimum spacing between the trailing edge and the pusher prop. Would the same rule apply to the slot dimensions?
  6. Jul 16, 2019 #6
    12,038
    3,468
    RC planes with the prop in a slot are really loud. Two or three times louder. There use to be a couple of kits out there. Probably gone now. I think Laddie Mikalasco (sp) designed some. Pretty prolific.
  7. Jul 16, 2019 #7
    slevair
    slevair
    slevair
    Oct 7, 2010
    112
    41
    (6TN5) Pulaski, TN / USA
  8. Jul 16, 2019 #8
    7,323
    2,106
    I think you're doomed to a long propshaft. That fixes the cg problems nicely, but brings new issues to solve. Have you chosen an engine?
  9. Jul 16, 2019 #9
    13,152
    5,063
  10. Jul 16, 2019 #10
    plncraze
    plncraze
    plncraze
    May 12, 2006
    1,683
    376
    There was a German motor glider with prop running between the vertical and the rudder. The caption for the picture said vibration issues. I can't remember if it was Strojnik or Carmichael (spelling!).
  11. Jul 16, 2019 #11
    12,629
    2,577
    Just move the wing lower.
  12. Jul 16, 2019 #12
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,266
    1,469
    Marion, Ohio
    No.
    This is just a theoretical question.
  13. Jul 16, 2019 #13
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,266
    1,469
    Marion, Ohio
    Uh, wouldn't that be the same as moving the engine higher? And there are practical limits to moving the wing lower, like running into the ground maybe?o_O
    Then you run into problems with the line of thrust being too high above the CG, and the resulting pitching moment change with thrust.
  14. Jul 16, 2019 #14
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,266
    1,469
    Marion, Ohio
  15. Jul 16, 2019 #15
    12,629
    2,577
    Not quite the same. There are practical reasons for not putting the engine and prop inside the wing also. Actually, a slightly high thrust line is ideal with no pitch change. Somewhat higher might get a minor pitch change. All low wing airplanes have a high but ideal thrust line because the increased speed with increased power would normally require a trim down change if the thrust line was low like a high wing.
    A low wing doesn't hit the ground with a bit of dihedral.
    The Custer channel wing curves the wing under the props.
  16. Jul 16, 2019 #16
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,266
    1,469
    Marion, Ohio
    I was trying to be funny with that comment, BBerson
    The original statement implied keeping the engine fixed and lowering the wing.
    By the way, what happened to all the good ole' emojis we had on the old forum software?
  17. Jul 17, 2019 #17
    7,323
    2,106
    If the mountain will not come to Mohammed, then Mohammed shall go to the mountain:
    [​IMG]
    blane.c likes this.
  18. Jul 17, 2019 #18
    12,629
    2,577
    I knew a guy in Alaska that built a twin boom, single engine, Custer channel wing.
    stanislavz likes this.
  19. Jul 17, 2019 #19
    slevair
    slevair
    slevair
    Oct 7, 2010
    112
    41
    Just google Archon plane in Greece.
  20. Jul 17, 2019 #20
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,266
    1,469
    Marion, Ohio
    Ducted fan, not prop-in-slot tailless.
