aeromike49
I have been searching for a supplier of a right angle nut plate and have not been able to find a retail supplier? I need 7 of something like a MF6001-08 which has a floating self lock nut plate - 8/32 threads. Apparently these are not popular anymore as Aircraft Spruce discontinued them. I can only find wholesale sellers that want a $50 minimum order - since this is for an experimental aircraft I can use a similar item but have not been able to find such an item in small quantities. Prices vary from $11 each to less than $5 each for the MF6001-08 item - this will be used to attach a glare shield to the instrument panel and airframe and must be of structural quality. Any suggestions or sources would be helpful. Thanks -
