Radial engine oil consumption
cheeka
Jul 15, 2016
30
Morgan Hill, CA
Is the oil consumption on a radial engine high only because of poor scavenging from the crankcase? Have they been completely phased out or are there new designs being developed?
13,614
Except for the small ones for the homebuilt or RC communities, nothing new is being designed. Turbines killed the radial engine long ago. They leak oil mostly from period when manufactured. That and oil was cheap. Modern overhauls of most radials have pretty acceptable consumption. Sitting, they still have lower cylinder drain back concerns, but that is just operating a radial.
9,366
Reminds me of my Jeep, "It's not leaking, it's just marking its territory."
Radials once were the best way to get adequate cooling in large displacement piston engines without going to the complications of liquid cooling, at the cost of aerodynamic drag and mechanical complexity. Nowadays, turbine engines have all but completely taken over the high power applications, so radials are mostly relegated to nostalgia applications, with no real technological advances.
Chris In Marshfield
Jan 29, 2008
1,283
Germantown, WI USA
Some Heli friends said the same about the H-46 in the Navy. If it's leakin', it's workin'. It's when it stops leakin' that you start worryin'.
That said, I loves me some round engine.
