Question About Running 50/50 Blend of Aeroshell and Synthetic
Discussion in 'Firewall Forward / Props / Fuel system' started by HomeBuilt101, Jan 26, 2020.
  1. Jan 26, 2020 #1
    HomeBuilt101
    HomeBuilt101
    HomeBuilt101
    Oct 20, 2015
    272
    18
    Aguila AZ
    I am considering running a 50/50 blend of Aeroshell 100W conventional oil and 15W-50 synthetic.
    Yes I heard that pure synthetic was tried in 100 LL AVGAS engines and there was problems because the synthetic oil did not have detergent properties and it was not washing away the contaminants so running 100 percent synthetic is most likely not good.
    That is disappointing because the lubrication properties and warm oil viscosity of synthetic oil is superior to the conventional oil...so what does the collective think about a 50/50 blend??? It would be able to achieve the best of both products.
    Has there been any studies on this thought with respect to AVGAS 100 LL engines?
    Any thoughts would be greatly appreciated!!!
  2. Jan 26, 2020 #2
    Super Moderator Staff Member
    Apr 4, 2007
    8,831
    3,178
    I don't know, but I bet it's been discussed on the Pilots of America forum, you might want to poke around there.
    From what I've heard the big problems with synthetic aircraft oils were some years with the early Mobil 1 aviation oil. Presumably today's players, Aeroshell and Philips, have got it right by now.
    I forget the exact thought process but when I was looking at oils I concluded the synthetic oils didn't really offer any advantage for me.
    Pops likes this.
  3. Jan 27, 2020 #3
    TiPi
    TiPi
    TiPi
    Aug 25, 2019
    176
    162
    Mackay (AUS)
    What generally happens is the synthetic oil properties get degraded to the mineral oil level as the mineral base oil is now the lowest common denominator. The synthetic portion is just wasted.
  4. Jan 27, 2020 #4
    12,039
    3,469
    Run any modern ashless dispersant once engine is broken in. Oil is like religion. List of oils in descending order as I use them. Phillips 20-50xc, Aeroshell 100, Aeroshell 15/50. Unlike turbine oil, mixing causes no problems. I use to mix in cars when there was no option. I would put some cam guard in if that makes you feel better. What is on the market now is OK with 100LL.
  5. Jan 27, 2020 #5
    7,325
    2,106
    I thought that religion was divisive than oil?
  6. Jan 27, 2020 #6
    ncmc47
    ncmc47
    ncmc47
    Jan 3, 2016
    11
    1
    Valentine Nebraska USA
    I thought AeroShell was a semi-synthetic
  7. Jan 27, 2020 #7
    Sep 18, 2008
    5,006
    2,167
    Its 15W50 is.
