• If you have bought, sold or gained information from our Classifieds, please donate to HomeBuiltAirplanes and give back.
    You can become a Supporting Member which comes with a decal or just click here to donate.
Parts For Sale Pilatus PC-9/A Spares - surplus to my restoration and spares needs
SpamIsHam
Jul 5, 2022
35
Sydney
I am currently typing up my build thread for the other forum, but thought I might quickly post these items before my ADD brain gets distracted.
I know its not really the usual audience for this type of aircraft but no harm in posting it I guess!
All the below come with CAMM2 data and are serviceable with their continuity tags and paperwork unless otherwise noted. Most of these parts are new in box.
There is obviously a lot there so I wont put a price on each part here... if there is something you need PM me and if you are interested in taking the whole lot I'm happy to work out a good deal.
Anyway, I have available surplus to my restoration needs and future spare parts needs the following PC-9/A spare parts (sorry long list!):
Flap Assy Inner LH 557.52.09.009 513 1
Flap Assy Outer RH 557.52.09.008 542 1
Flap Assy Inner LH 557.52.09.009 542 1
Flap Assy Outer LH 557.52.09.007 144 1
Flap Assy Inner LH 557.52.09.009 35.562 1
Flap Assy Outer RH 557.52.09.008 2
Skin Panel RH O/B Top 557.32.09.050
Panel Skin 557.32.09.049
Fairing Aircraft NSN: 1560-66-134-1260
Panel Skin 557.32.09.050
Stringer Aircraft 1560-66-159-8359
Stringer Aircraft 1560-66-154-0164
Spar Aircraft 1560-17-117-4428
Stringer Aircraft 1560-66-159-2984
Strut Shock MLG L/H 532.10.09.075 516
Strut Shock MLG RH 532.10.09.070 5687011
Panel Skins; Panel, Skin 571.10.09.090 B
Panel, Skin 557.32.09.048
Panel, Skin 557.32.09.047
Panel, Skin 557.32.09.046 A
Stringer RH 553.20.09.302
KFS 576A ATC XPDR Control 071-1276 2008, 2032, 1916, & 2035
4 Set Emergency Oxygen MBEU100618 (8 units remaining)
GPS500 Standard 010-00176-01
Struct Repair Kit 500.50.09.151
MIS910 Glass Cockpit Upgrade and Modification Kit - including:
Computer Secondary Air Data 985.90.03.049 MO 16715
Magnetometer Heading Sensor 985.90.03.050 MO 16438
Air Data Computer 065-0082-0011 534.17.09.013 11408
Kit, INSTLN, KDC481T 985.90.03.033
Display SFD Repeater 975.96.32.705
MO16618 Mod Kit - Cockpit Rear 500.60.09.025
Mod Kit - Cockpit Front 500.60.09.024
Mod Kit - Radio Rack Kit 500.60.09.026
Mod Kit - Antennas 500.60.09.028
Mod Kit - Wing 500.60.09.027
Mod Kit - EL/AV 500.60.09.029
Mat Aircraft Ground Servicing 1730-66-131-7086
Rear cockpit Glare Shield 539.11.09.846
Big Bottom Counterweight 5552009269
Cam Operated Switch 9733031305
Pressure Sensitive Adhesive Tape 7510.01.646.3220
Switch Guard 5930-14-546-6975
Lug Terminal 5940-66-127-3383
Filter Element 3059779-01
Cabin Air CLE Gasket 968.20.12.143
Toggle Switch 973.52.63.036
Struct Repair Kit 500.50.09.153
Elastic Strip Lacing 917.53.30.207
Plug Connector 5935-14-548-4606
Piston Ring Set 3040-99-730-4766
Power Cable Assembly 6150-66-119-9480
Ejection Seat Apron 1680-66-131-7651
Various other items Flap Assy Inner LH 557.52.09.009 537
Rudder Assy 555.40.09.067 541, 559, 516 3
Panel Skin 553.30.09.052 3
Flap Inner LH 557.52.09.009 250
SRM Kit 57-21-00 Repair 0 500.50.09.157
Strap Webbing 1680-66-131-7680
O-Ring AS3209-141 Pipe Assy 571.70.09.005
Bearing Ball Airframe 3110-99-716-9337
Hinge Rudder Bolt 555.30.09.040
Support Structural Component 112.35.07.469
Lamp Incandescent 6240-66-135-6460
Various other parts...
Rubber Strip 9320-66-134-0654
Line Canopy Withdrawal 1670-99-139-4499
Tube Assembly Metal 4710-66-156-6057
Lens Light 6220-12-129-3873
Struct Repair Kit 57-10-01 500.50.09.151
Housing 310797-01
Support Angle 571-10-09-452
Lever Lock Release 5340-66-133-1990
Tank Assy Aerobatic 528.20.09.045 60
Bearing Ball 3110-01-123-2323
Cover Access 5340-66-154-4334
Counterweight Assy 555.20.09.102
Sampler Liquid 6695-66-153-2521
Support Structural 557.22.09.635
Cover Battery 307.91.71.004
Arm Assembly Torque Landing Gear 1620-66-154-4093
Frame Access Hole Aircraft 1560-66-160-3181
Circuit Breaker 5925-12-337-8732
Washer 3009022 Nipple Assembly 4730-99-666-6614
Bush Self-Lub Str ST 941.22.55.238
Bolt Machine 5306-00-151-2612
Lens Light 6220-66-131-7176
Support Structural Component Aircraft 1560-66-164-0988
Valve Pneumatic Tire 2640-01-340-3204
Marker Identification 7690-66-121-5239
Pin Firing Rack End Time Release 1680-99-762-1510
Pin Rivet 5320-01-161-2629
Elbow Flange To Tube 4730-99-611-8986
Plate Insulation 1-6 525.73.09.255
Plate Insulation 1-12 525.73.09.274
Spar Aux Outer LH Assy 557.22.09.321
Pipe Assy 525.80.72.064 4
Overwing Fuselage Fairings
Copper Piping Used in Oxygen System
Stainless Steel Piping Used in Nitrogen System
Aircraft Maintenance Template 513.55.09.038
Panel, Skin 557.32.09.078 Panel, Skin 557.32.09.083
Panel, Skin LH 555.40.09.039
Webplate, Spar 113.35.07.028
Panel, Skin 557.32.09.083 2
Modification Kit, Aircraft Components 1680-66-156-4508
Fairing Wing 648.34.43.323
Aircraft 1560-66-162-7507 Wing Tip Panel LB18 557.33.08.033 Trim Tab Assy LH 557.51.09.181
Skin, Nose 555.40.09.068
Piston, Main LDG 532.10.09.165
Fairing Rear, RH 557.31.09.320
Fairing Rear, RH 557.31.09.319 REAR C/PIT RH NAD
Case Panel 625.14.09.048
Vertical Stab Assy 555.30.09.050 56
Main Wing Assembly 557.06.09.953 512
Main Wing Assembly 557.52.09.952
Main Wing Assembly 557.05.09.952 514
Martin Baker MK11 Ejection Seats:
Ejection Seat AU11A-1 93 1
Ejection Seat AU11A-2 162 1
Ejection Seat AU11A-1 54 1 ***SOLD AWAITING EXPORT***
Cushion Assembly MBEU116936 ISS:02 ***SOLD AWAITING EXPORT***
Locking/Loading tool MBEU62667 Nut Self-Locking Plate MS21048-08 Pin Assy Rack & Pinion MBEU62370 Flap Parachute Pack MBEU12835PA Container Assy Surv Aids MBEU5114DP Flap Assy Rear Parting MBEU12757PA =============================================================
Yellowhammer
Feb 21, 2020
809
Born In Alabama, reside: Louisiana (unfortunately)
Housing 310797-01
One of my favorite airplanes of all time. In fact, my next build will be the Tucano Replica.
-Yellowhammer
SpamIsHam
Jul 5, 2022
35
Sydney
Also, do you have a CMM (Component Maintenance Manual) or IPC (Illustrated Parts Catalog) available?
I don’t have one available in my hands right now, but I can get hold of one fairly easily - they will want $$$ for it though. Let me see what I can do and I’ll get back to you on PM :)
SpamIsHam
Jul 5, 2022
35
Sydney
Not those. See picture.
Unfortunately no, I don’t have any of these as loose spares - Im not sure where these fit, are they centre fuselage under the cockpit or in the centre section of the main wing? If in the wing there may be units fitted to the two main wing assembly’s I have left - but that said, I wouldn’t seperate them for parts so it’s probably not much help to you.
pylon500
Dec 26, 2003
589
Taree Airport Australia
-Yellowhammer
You know he's actually talking about the Pilatus PC-9, not the Tucano, that said, the guys that make the Tucano kit are (I think) getting ready to release a Beech Texan II scale replica (which is a licence built PC-9)...
SpamIsHam
Jul 5, 2022
35
Sydney
Yellowhammer
Feb 21, 2020
809
I couldn't remember who Beechcraft acquired the rights from. Interesting to learn about the new model coming out of Flying Legends. Frank and the good folks over there are friends of mine. Have not spoken to any of them in about 6-8 months. It is time to touch base with them.
-Yellowhammer
pylon500
Dec 26, 2003
589
Don't know how I missed that post, but yeah, that's me, and a couple of mates.
I don't drive much social media, so I let the other guys do that, and our PC-9's are only 80% scale. we started at 70% like the scaled Tucano, but I crunched some numbers and thought the wing may be just a little small to get our ultralight stall speed, so I decided to bump the wing and tail up to 80%, and then figured; 'We're still putting 100% pilots in this', so I might as well make the whole thing 80%.
We're up in Taree if you're ever up this way...
SpamIsHam
Jul 5, 2022
35
Sydney
If your planes end up looking anywhere near as good as the Texan posted above then they are going to look amazing :) Cant wait to see them - hows your fuselage sections going?
SpamIsHam
Jul 5, 2022
35
Sydney
If your weren’t so far down the track with these already I would be hitting you up to make a 5th set of everything!
… or if you’re up for the challenge of a full size 1/1 replica fuselage build, I have spares of all the skins, a spare engine cowling, spare vertical stab, horizontal stab, main wing set, control surfaces, rudder, landing gear, cockpit kit, fairings and heaps of other bits and pieces in all these bits listed above that would pretty much make up the rest of the airplane ;)
