planeDave
I Have the newer style rectangular main spar partial parts kit, This has plans, build manuals [old and newer] , all bent pcs ribs ect, fiberglass parts, extrusions,and any hard to make
parts
Plus a prop. winshield, tailwheel and bracket, pito tube
and about all the aditional aluminum tube and sheet you will need plus most of the nuts bolts, bearings, rivets' you will need about $400-$800 in rivets cables assorted other hardware to make it equal to what they sold as a full airframe materials kit, then you will need wheels brakes, covering paint, eng, instruments
factory. ribs are in origonal box, I fabricated the aileron and rudder horn and had the elevator and rudder hinges machined, out of the extrusion, all other pcs are un drilled or un cut
as for shipping it could be put in ONE CRATE 13'X3'6"X3' 500-600LBS OR EASILY PICKED UP WITH A WAGON MINIVAN OR SMALL PICKUP WITH ROOF RACKS,
If you are serious please call me 978 750 0677 mornings or eves are best Thanks Dave $3500.00 or BRO
Renegrade (Murphy)
parts
Renegrade (Murphy)
