K.O.H.L.E.R COMMAND VTWIN CH750 based engine
4,721
Could part of the heat issue have been fuel? It was designed to run on 72 octane?
It could well have played a part but I still think “hot enough to burn up magnetos” puts a pretty hard cap on how much power you want that engine to try and make.
WonderousMountain
Apr 10, 2010
2,750
Bellingham, Wa
Anyone have a Jabiru Crank mounting spec sheet lying around?
I'm looking to work up a mounting flange affixed to the fly side taper shaft.
Bonus points if you can find Sae #2 flange with lightening holes shown.
Hmmm, maybe start with Kawasaki big block crank Fly taper drawing,??
CK LouPai
TiPi
Aug 25, 2019
620
Peeramon (AUS)
CK LouPai
no spec sheet but the installation drawing from the Gen4. Straight face mounting with 3 dowel pins and 6 retaining bolts.
Marc W
Mar 31, 2017
893
Colorado
I have a Jabiru 3300. 4" bolt circle with 1/2" drive lugs. I can measure the lightening holes today.
Marc W
Mar 31, 2017
893
Colorado
Well I couldn't measure. I thought I taken the cowling off but it is still on. I might get it off in a few days. Looking between the spinner and cowl at the hub, it looks like the lightening holes are 5/8" to 3/4".
