Instrumentation Tubing
Discussion in 'Instruments / Avionics / Electrical System' started by GESchwarz, Aug 31, 2019.
  1. Aug 31, 2019 #1
    GESchwarz
    GESchwarz
    GESchwarz
    Oct 23, 2007
    1,179
    112
    Is there a minimum tubing ID for pitot and AoA systems? The length of the run for these tubes is about 16 feet.
  2. Aug 31, 2019 #2
    6,552
    5,333
    Shouldn't be in theory, however I would also make the tubes 3/8 ID if I could. 16 ft. is pretty far, and adding line losses or whatever small hysteresis comes form viscosity and friciton could potentially skew the readings a bit.
  3. Aug 31, 2019 #3
    Super Moderator Staff Member
    Oct 19, 2003
    6,148
    3,455
  4. Aug 31, 2019 #4
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,564
    3,398
    Mojave, Ca
    wsimpso1 likes this.
  5. Aug 31, 2019 #5
    10,191
    6,912
    The only question that I have about the small tubing is how well it will drain any water, especially the static line. It may be a long time before you have any water issues out there.
  6. Aug 31, 2019 #6
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,564
    3,398
    Mojave, Ca
    Agreed. Thats my one area of concern too.
  7. Sep 2, 2019 #7
    C Michael Hoover
    C Michael Hoover
    C Michael Hoover
    Aug 24, 2019
    20
    8
    You are not measuring flow, but only measuring relative pressures. The tubing size should make a difference of exactly "zero". If either pitot or static sources are subject to water ingress, then a drain needs to be considered.
  8. Sep 2, 2019 #8
    7,317
    2,102
    There will only be flow when pressures change. Small tubing may introduce some lag, but I doubt that it would be noticeable. Water could be problem in any line. Perhaps the annual could include blowing the lines out?
    I'll be using the smallest, lightest stuff I can find.
  9. Sep 2, 2019 #9
    12,037
    3,466
    T fitting at a low point with 4-6” line pointed down capped off is how most do a sump for pitot water, pretty standard.
    Pops likes this.
  10. Sep 2, 2019 #10
    7,464
    6,437
    Or find one of the plastic bottles Cessna used on the C-150/172's.
    TFF likes this.
  11. Sep 2, 2019 #11
    7,317
    2,102
    A bottle on thin line may make lag noticeable.
  12. Sep 2, 2019 #12
    10,191
    6,912
    My concern about small (1/8” OD) static and pitot lines, stated above, is their poor capacity to drain water (condensate or rain) due to the tendency for capillary action.
    Unobstructed small tubing will have less lag when driving an EFIS.
  13. Sep 2, 2019 #13
    7,464
    6,437
    Apparently Cessna has no problems. Cessna uses 1/4" dia tubing.
  14. Sep 2, 2019 #14
    12,037
    3,466
    Mid level Regional planes use the same stuff. I will say Collins has these neat quick disconnect jars on the air data computers, but the lines to them are the same plastic.
  15. Sep 3, 2019 #15
    7,317
    2,102
    What is the science behind less lag? I would model it as a Helmholtz resonator, where lag would go down with larger tubing.
  16. Sep 3, 2019 #16
    10,191
    6,912
    The smaller diameter tubing driving an EFIS, as opposed to a bellows or bourdon tube, will have a smaller volume of air to compress or expand with a change in static or dynamic pressure. But even with steam gauges, lag is not significant.
  17. Sep 3, 2019 #17
    7,317
    2,102
    I had a look at weights for nylon tubing
    1/4 0.050: 1.39 lb/100ft
    1/4 0.030: 0.95lb/100ft
    3/16 0.025: 0.58lb/100ft
    5/32 0.025: 0.47lb/100ft
    1/8 0.025: 0.35lb/100ft
    1/8 0.015: 0.25lb/100ft
    We use literally miles of the stuff at work. Air and lube lines on injection moulding presses. It does not seem to fatigue, the push fit fittings are extremely reliable, though not perfect. Replacement is usually because an irresistable force (up to 1400ton press) has had a wrench or some other lump of metal left in a way, which catches a line when the press closes. Well, the line is tough good, but not that tough... Sometimes the lines are not tied up well, and with an operation or two per minute, will wear through rubbing on a way. That still takes a really long time, though. I've just persuaded the boss to buy me some 3/16 line to fix the abraded lube lines on a press with an orange monochrome screen. It's one of the older ones...
    The push fit fittings have an irritating habit of staying in the bottom of my pockets in my small change when I empty tools out before I go home. I just had a look, the plastic ones have a grey-ish body and orange push bits. Marked SMC and S'pore
  18. Sep 3, 2019 #18
    7,317
    2,102
    The volume is less, but the area for the gas to flow down is less, too. If it is just a blank end tube, lag should be the same. If there is a cavity volume V at the gauge, it will vary with the sqrt(V*A/L). Unless the entrance hole is significantly smaller than the tubing?
  19. Sep 3, 2019 #19
    Jul 30, 2005
    13,963
    5,586
    Interesting side-note of some relevance: Dr. Bowers in one of his talks at the ESA Workshop this year showed a custom pressure-measuring system, with 96 channels (and therefore, 96 individual tubes), that his students designed and built for some of the Prandtl-D work before he retired from NASA. The tubing on all of this system, leading from the pressure tap ports on the wing to the sensors in the unit, was 1/8" I.D. at most, based on comparison to some other items in the photo. Very probably smaller.
    Seems, for simply measuring pressure, small tubes don't make much difference. Keeping them clean and clear of water is another matter, and not of concern for a research aircraft such as Dr. Bowers was describing.
  20. Sep 3, 2019 #20
    7,317
    2,102
    Small tubes make zero difference to measuring pressure. I beleive that Dr Bowers was testing stuff in a desert? Condensation isn't a big concern there...
