How far are we from the perfect electric "homebuilt" ?
Discussion in 'Hangar Flying' started by Speedboat100, Aug 20, 2019.
  1. Sep 14, 2019 #321
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    378
    98
    Lt
    Yup.
    Inverters same. And cables high voltage....
    2x7-10 kw is much easier and much cheaper, than one 20kw. And lovely china made 154120 sized brushless, do hold maximum 7 kw on nominal..
  2. Sep 14, 2019 #322
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    378
    98
    Lt
    Not only. they have to narrow flight envelope,a nd are to sensitive to deviation from design point - even rigidity in wrong place, can make things worse. Have you read paper attached by my about bkb-1 ? For me it is must to read on any attempt to design viable flying wing. And after reading all that i have found - that ugly thing with fixed tapered wing and dual boom to allow bigger prop looks totally doable in any bigger garage. Biggest problem - how to make it mold less and good enough.
  3. Sep 15, 2019 #323
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,230
    1,447
    Marion, Ohio
    PIOS?????
  4. Sep 15, 2019 #324
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    378
    98
    Lt
    Pilot induced oscilation.
  5. Sep 15, 2019 #325
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,798
    469
    krakow,poland
    =it is concerned with "BKB-1" tailles glider,constructor/builder Stefan Brochocki.
    (simple,cheap club glider)
    http://www.twitt.org/Brochocki.html
    =after first fly tests in Canada glider was moovet into USA,Seattle,
    and Witold Kasper personally modyfied wingtips and rudder systeme for extending fly
    envelope=vortex flow,unbelivable !!!
    aerobatic capebilites ,
    http://www.twitt.org/tufts-r.jpg
    http://www.twitt.org/kasperminutes.htm
  6. Sep 15, 2019 #326
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    758
    60
    Europe
    I dont like the insanelish amounts of sweep in the trailing adge on the Al Bowers wings...I just want mine to mush...in a stall...and when speed is regained ailerons are back too. Also I have very effective rudders..so spin tendency is eliminated...with strong leading edge sweep. With 10 kg/m2 wingloading...you hardly stall at all.
  7. Sep 15, 2019 #327
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    378
    98
    Lt
    With 10kg/m2 your ending with rigid d box + rag of any kind on ribs. And reducing max speed..
  8. Sep 15, 2019 #328
    Mad MAC
    Mad MAC
    Mad MAC
    Dec 9, 2004
    478
    214
    Hamilton New Zealand
    Depending on where (or high) one operates, one might need battery heating which possibly points one in the direction of a lumped battery pack with liquid heating / cooling as required using the motor cooling system.
  9. Sep 15, 2019 #329
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    758
    60
    Europe
    "Use the styrofoam and shell structures Luke !"
  10. Sep 15, 2019 #330
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,230
    1,447
    Marion, Ohio
    Then just make it PIO instead of PIOS.
    By the way, this is discussed in Nickel's "Tailless Aircraft" book.
  11. Sep 15, 2019 #331
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,230
    1,447
    Marion, Ohio
    In other words, you like a large amount of Taper? And a small aspect ratio?
  12. Sep 15, 2019 #332
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    758
    60
    Europe
    Lite plane almost like delta wing...more speed and range.
    https://engineering.purdue.edu/AAE/...aceSystems/SoS_Day_pdf_files/ASD_2010_2_1.pdf
    Wetted aspect ratio...is what I am after.
    https://en.wikipedia.org/wiki/Aspect_ratio_(aeronautics)
    The wetted aspect ratio considers the whole wetted surface area of the airframe, , rather than just the wing. It is a better measure of the aerodynamic efficiency of an aircraft than the wing aspect ratio.
    Illustrative examples are provided by the Boeing B-47 and Avro Vulcan. Both aircraft have very similar performance although they are radically different. The B-47 has a high aspect ratio wing, while the Avro Vulcan has a low aspect ratio wing. They have, however, a very similar wetted aspect ratio.[15]
    My Supa-fnx has 1.8 wetted aspect ratio ( bigger2.4 )...second to none....with that amount of sweep. That yields about 25-30 L/D.
  13. Sep 15, 2019 #333
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    758
    60
    Europe
  14. Sep 15, 2019 #334
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    378
    98
    Lt
    Would you mind to make short list of problems listed in what book ?
    For me, Norman image of flying wing transformation to low a/r, short fuselage planform is nice and tells a lot. From efficiency, to stability.
    Could any one point me to gallery with composite wing / wing tip connectors ?
  15. Sep 15, 2019 #335
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,230
    1,447
    Marion, Ohio
    No, I wouldn't mind. Except it would be hard to make a short list. And it would start another thread drift.
    If you are really interested, you can buy the book online. Or get it through inter-library loan at your local public library. If you are really lucky, your local public or college library will have a copy.
  16. Sep 15, 2019 #336
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    378
    98
    Lt
    Ok. Will find it. For me flying wing is closed topic..
  17. Sep 15, 2019 #337
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,798
    469
    krakow,poland
    -in my opinion,GOOD flying wing is better as tailed,classical aircraft...
    f.e.=SWIFT(Aeriane) / ARCHEOPTERYX.
    stanislavz likes this.
  18. Sep 16, 2019 #338
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    378
    98
    Lt
    Yes. Agree. Problem - how to design and build it. It gives hery low margin error.
  19. Sep 16, 2019 #339
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,798
    469
    krakow,poland
  20. Sep 16, 2019 #340
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    758
    60
    Europe
    How do you fight the PIOs ?
    Less moving control surfaces ?
