How far are we from the perfect electric "homebuilt" ?
Discussion in 'Hangar Flying' started by Speedboat100, Aug 20, 2019.
  1. Sep 13, 2019 #301
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,850
    480
    krakow,poland
    =KASPERwings have STATIC stability and controll,
    i.e. it can "fly" with ZERO forvard speed !
  2. Sep 13, 2019 #302
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    392
    100
    Lt
    henryk likes this.
  3. Sep 13, 2019 #303
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    832
    75
    Europe
    Yes the wing tip brakes seem a bit odd...and might be a menace to a beginner.
  4. Sep 13, 2019 #304
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    832
    75
    Europe
  5. Sep 13, 2019 #305
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    832
    75
    Europe
  6. Sep 13, 2019 #306
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,269
    1,471
    Marion, Ohio
    http://airfoiltools.com/
  7. Sep 13, 2019 #307
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    832
    75
    Europe
  8. Sep 13, 2019 #308
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    392
    100
    Lt
  9. Sep 13, 2019 #309
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    392
    100
    Lt
    I will try to get in touch with them, they are using carbon rods tech, from Jim.
    But - twin boom configuration has beauty in placing wheels on boom, safer prop (there was incidents then prop have not deployed in time). Easier to make and smaller molds - especially, with improved untapered wing by Strojnik .. Almost same as building two gliders in place of one.
    Ps. my idea of using same airfoil for tail was wrong, and no one fixed it.. :)
    Will try to play with moldless wings, i do have cnc foam cutter..
    And post me to gallery of composite wing/ wingtips connectors..
  10. Sep 13, 2019 #310
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,269
    1,471
    Marion, Ohio
  11. Sep 14, 2019 #311
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    832
    75
    Europe
  12. Sep 14, 2019 #312
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    832
    75
    Europe
    I was wandering if a 14,2 m ( max 3 seater ) spanning all electric flying wing could have a FBW system...and an autopilot...it might give more customers.
  13. Sep 14, 2019 #313
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    832
    75
    Europe
    This ought to fly 1 hr at 10 kg/m2 wing loading. It has Eppler 548 ....a 0 moment foil.
  14. Sep 14, 2019 #314
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    832
    75
    Europe
    How about electrifying Pelican ?
  15. Sep 14, 2019 #315
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    392
    100
    Lt
    Me not. Have to nice childs.
    To narrow cg range, to tricky to fly...
  16. Sep 14, 2019 #316
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    832
    75
    Europe
    PIOS tendency increased ?
  17. Sep 14, 2019 #317
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,269
    1,471
    Marion, Ohio
    A zero moment isn't essential. In fact you can use just about any airfoil, but low moment is highly beneficial. You are going to need some kind of nonlinear twist to ensure that the stall starts at about 30-40% of the half span. The AoA will then automatically adjust itself for zero moment.
    (A bit more complex than that, but want to avoid thread drift again)
  18. Sep 14, 2019 #318
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    832
    75
    Europe
    I was thinking about twisting just the end piece of the wing..last 20%.
  19. Sep 14, 2019 #319
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,269
    1,471
    Marion, Ohio
    You should have the largest amount of twist at 30-40% of the half-span. That is where the stall will start, leaving the ailerons still effective.
    Look up Al Bowers paper on the PRANDTL-D. Why reinvent the wheel---I mean wing:)? He has already figured it out! The important thing is the general shape of the twist distribution, not the absolute amount of twist.
    stanislavz likes this.
  20. Sep 14, 2019 #320
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,269
    1,471
    Marion, Ohio
    Out of curiosity, I was just looking at some 20kw-30kw motors.
    Have any of you considered that they use liquid cooling? At least the ones I have looked at. That means a radiator, pump, and coolant, which in turn means more weight.
    Another thought. If you use "5 gallon size" battery pack that weighs about 100 pounds, you can distribute the batteries to get the desired mass distribution. The motors I was looking at weight about 35 pounds, without cooling system. This is one advantage over a 95 pound IC motor, and you don't have to worry about the CG changing as the batteries are drained.
