Hinges
Discussion in 'The light stuff area' started by cdlwingnut, Oct 25, 2017.
  1. Oct 25, 2017 #1
    cdlwingnut
    cdlwingnut
    cdlwingnut
    May 25, 2015
    444
    713
    Iowa
  2. Oct 25, 2017 #2
    9,499
    6,255
    That is very thick. What are you building, and are the hinges continuous or just short sections?
    I would use the MS200001P hinge. It is extruded. Scroll down the ACS page you linked to to find it.
  3. Oct 25, 2017 #3
    BoKu
    BoKu
    BoKu
    Aug 16, 2013
    2,275
    2,837
    Western US
    That doesn't match any standard aircraft piano hinge that I know of. Can you post a photo of that part of the plans so we can get a better idea of the context?
    --Bob K.
  4. Oct 25, 2017 #4
    cdlwingnut
    cdlwingnut
    cdlwingnut
    May 25, 2015
    444
    713
    Iowa
    it's on a pdf file but its for my ragwing ultra piet
    it says .060 by 1 1/2 wide .125 pin, three for the rudder and 6 for the elevators,
    i ordered the ones from ACS the A and P and my tech counsler said they would work but the pin seems small
  5. Oct 25, 2017 #5
    BoKu
    BoKu
    BoKu
    Aug 16, 2013
    2,275
    2,837
    Western US
    Can you get a cellphone photo of the screen? A picture is worth ten hundred words.
  6. Oct 25, 2017 #6
    cdlwingnut
    cdlwingnut
    cdlwingnut
    May 25, 2015
    444
    713
    Iowa
    here it is
    BoKu likes this.
  7. Oct 25, 2017 #7
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    466
    645
    Tehachapi, CA
    Well, since the drawing says steel at 0.060" thick with a 0.125" pin, I'd say that standard AL aircraft hinges would in no way be adequate, _IF_ the steel hinges are actually required. Given the size, thickness and pin diameter, they kind of look like:
    https://www.grainger.com/product/GRAINGER-APPROVED-2-x-1-1-2-Butt-Hinge-with-3HTE6
    which is a door hinge. P/N's 16175A181, 16175A181 or 15095A33 at McMaster-Carr could also be easily modified. Depends if you want SS.
    BoKu likes this.
  8. Oct 26, 2017 #8
    cdlwingnut
    cdlwingnut
    cdlwingnut
    May 25, 2015
    444
    713
    Iowa
    BoKu likes this.
  9. Oct 26, 2017 #9
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,237
    553
    capital district NY
    The 257's are crimped loops and can be pulled apart? The 001's are extruded so the loops are closed and cannot be pulled apart? .007" isn't much common sense says it should be ok, but you would have to calculate loads if you wanted to be sure. Also generally stainless is a little less strength than some other steels used for structural.
  10. Oct 26, 2017 #10
    6,699
    1,765
    Isn't an Ultra-Piet a door hinge kinda plane?
    cdlwingnut and BoKu like this.
  11. Oct 26, 2017 #11
    6,699
    1,765
    A quick google turned up a pdf of the plans. I found an aircraft type piano hinge with number in the plans, then found the one in question. Zooming in, looks like a stamped hinge. Ie, door hinge type.
    BoKu likes this.
  12. Oct 26, 2017 #12
    cdlwingnut
    cdlwingnut
    cdlwingnut
    May 25, 2015
    444
    713
    Iowa
    where did you find that pictsidhe
  13. Oct 26, 2017 #13
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,237
    553
    capital district NY
    While a door hinge is generally more substantial I.E. "meatier" than a piano hinge, I doubt if a modern door hinge is made from the same alloy of metals as a door hinge from the 30's, I am basing this on the remodelling and construction experience I have. If you put a really old door hinge in your hand and then a new one they just do not have the same "heft".
  14. Oct 26, 2017 #14
    6,699
    1,765
    True, but the plans specify the heft. I'd be surprised if the steel was much different. Mild vs mild...
  15. Oct 26, 2017 #15
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,237
    553
    capital district NY
    I would be surprised if the steel was remotely the same from eighty years ago to today. It may be a good thing but maybe not? But unlikely the same.
  16. Oct 26, 2017 #16
    2,844
    1,586
    Don't forget, these aren't the 1929 Pietenpol Air Camper plans in question here, it's the Ragwing Ulta Piet which was designed around the mid 90's. It shares nothing with the airplane that inspired it.
  17. Oct 26, 2017 #17
    6,699
    1,765
    Aircraft hinges, with part number, are specified for the ailerons. If these hinges were as critical, I imagine they would also have an aircraft part number. They have dimensions instead...
    BoKu likes this.
