Cutting out airframe tubes - whats the best saw blades?
Discussion in 'Workshop Tips and Secrets / Tools' started by Zoomzoooie, Feb 14, 2018.
  1. Feb 14, 2018 #1
    Zoomzoooie
    Zoomzoooie
    Zoomzoooie
    Feb 14, 2011
    170
    3
    BC Canada
    It's been a a while since I've been back here. I've been planning modifications to my airframe.
    I have to cut out some of the 5/8" 4130 tubes for the modifications. I had already cut a few 3/3" tubes with a hacksaw and this took forever and wore the blades out very fast.
    I would like to know which hacksaw and reciprocating blades you would recommend for the 4130 in the airframe.
    ZZ
  2. Feb 14, 2018 #2
    8,880
    5,733
    I still have some (apparently no longer available) Heller Tool Co High Speed Max Hard Edge with Start-A-Cut teeth over the first three inches. I use 32 TPI for tubing. They were expensive back in the 1970’s, but well worth the cost.
  3. Feb 14, 2018 #3
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,546
    2,572
    Calgary, Alberta, Canada
    Sandvik makes pretty good blades.
  4. Feb 14, 2018 #4
    dcstrng
    dcstrng
    dcstrng
    Oct 17, 2010
    912
    321
    VA or NoDak
    I find an inexpensive angle grinder with a cutting wheel will go through almost anything, fast -- flapper wheel to finish...
    TejasNW likes this.
  5. Feb 14, 2018 #5
    Zoomzoooie
    Zoomzoooie
    Zoomzoooie
    Feb 14, 2011
    170
    3
    BC Canada
    I am weary to use a cutoff wheel, one slip or cut too close and another tube needs replacing. I will have to use a grinder with a flapper to finish off the excess.
    I came across these blades and they look like that would do the trick: http://www.diablotools.com/products/product/DS0908CF
    I watched some youtube videos and they look pretty good cutting through some thick hard metals including a file. A bit expensive, but they look like they last much longer.
    Anyone have experience with these?
    ZZ
  6. Feb 14, 2018 #6
    dcstrng
    dcstrng
    dcstrng
    Oct 17, 2010
    912
    321
    VA or NoDak
    Not familiar with that blade, but I've had good performance with that brand...
    On the other hand, if I can position myself comfortably/steadily enough to TIG weld (I'm a weekend hack), then I'm positioned solidly enough for the cutoff wheel (not to say it can't get away from me... mostly making sure the rotation doesn't suck me in where I don't want to go... )
  7. Feb 14, 2018 #7
    6,675
    5,552
    Very good.
    Use the smallest dia wheel so the wheel will have less leverage if it gets caught. For close spaces, I buy a thin, 1/32" x 4" dia wheels and drill a center 3/32" hole and cut small 1 1/2" or so wheels out with an aviation snips to use on my Dremel. Last many times longer and cut better the the small Dremel cut-off wheels.
  8. Feb 14, 2018 #8
    11,129
    3,012
    Cut off wheel for gross cuts. Harbor freight mini high speed grinder with carbide or diamond dremel flame or cylindrical bit to wipe away welds. Come up with some armor for hands and arms as the shards are painful. Face shield of course.
  9. Feb 14, 2018 #9
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    768
    157
    YMM
    Cold cut saw would technically be the proper way...
    But I have never seen one in a hangar truth be told. But no tempering issues microfractures etc.
  10. Apr 26, 2018 #10
    TejasNW
    TejasNW
    TejasNW
    Apr 23, 2018
    17
    5
    Houston Texas
    What is the best way to 'cope' or 'fish mouth' tubing? My engine mount calls for 5/8" .060 wall tube and has joints at non right angles, of course. I have been debating a 2 flute 5/8th end mill or a 5/8th hole saw on the drill press. If I could get your opinion on best hole saw blade in that small a size; or if their is better way; I would be grateful to hear your experience.
  11. Apr 26, 2018 #11
    5,882
    1,494
    For an engine mount and not many joints, you may be quicker just doing two cuts with a saw then touching up with a file or an angle grinder if you want to tighten the fit. Once you have the hang of it it can be done pretty quickly.
    Pops and BBerson like this.
  12. Apr 26, 2018 #12
    6,675
    5,552
    True, and buy 1/2 round files the same dia as each tube size that you will be using, helps make it quick and easy. Like you say, after you do a few and get the hang of it, takes about 10 minutes to do a 1/2"- 7/8" dia tube, larger tubes a little longer.
    When doing several of the same cuts in larger tubes I make a marking tube from the next size tube at .058 wall thickness. Picture of a Bearhawk landing gear jig with marking tubes for the larger LG tubes.
    Use this to cut the tubing. Also will need a vice to hold the tubing while cutting and filing.
    https://www.harborfreight.com/3-in-heavy-duty-electric-cut-off-tool-68523.html
    http://dogfeatherdesign.com/ttn_js/
  13. Apr 26, 2018 #13
    11,416
    2,093
    Yeah, just hacksaw or chop saw the end angles (rough cut about 1/8 long) Put it in position then grind off high spots till it fits. Might take four trips to and from the jig to the grinder. Both ends need to be fitted more or less together in stages till it fits in place.
    Hooch likes this.
  14. Apr 26, 2018 #14
    TejasNW
    TejasNW
    TejasNW
    Apr 23, 2018
    17
    5
    Houston Texas
    Gentlemen, Thank you for the responses and resources. The template creator I will have to spend some time playing with.
    I have seen saddle cuts on larger pipe, but did not think the smaller diameter would allow. I have some practicing to do. Again, thank you for the guidance.
    Little Scrapper likes this.
  15. Apr 26, 2018 #15
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,244
    3,145
    Wisconsin
    I made these videos about 5 years ago. Good luck.
    [video=youtube_share;CCqKmRu4Z94]https://youtu.be/CCqKmRu4Z94[/video]
    TejasNW likes this.
  16. Apr 26, 2018 #16
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,244
    3,145
    Wisconsin
    And video 23.
    [video=youtube_share;Db1TlB6VRYU]https://youtu.be/Db1TlB6VRYU[/video]
    Pops and TejasNW like this.
  17. Apr 27, 2018 #17
    TejasNW
    TejasNW
    TejasNW
    Apr 23, 2018
    17
    5
    Houston Texas
    Nice video series, Mike. You are helping a lot of folks overcome the 'unknown' factor; and helping them get into building. Kudos, Sir.
  18. May 14, 2018 #18
    Armilite
    Armilite
    Armilite
    Sep 6, 2011
    2,934
    228
    AMES, IA USA
    Here are some different Tools from Harbor Freight.
  19. Jun 27, 2018 #19
    wanttobuild
    wanttobuild
    wanttobuild
    Jun 13, 2015
    541
    49
    kuttawa, ky
    A small Rigid tubing cutter, Black, Red and Green handled tin snips and a medium grit Scotchbrite wheel.
    Have Fun!
    Ben
    H-Minus
