Clear Hatch Sealing Tape
Discussion in 'General Experimental Aviation Questions' started by HomeBuilt101, Mar 28, 2019.
  1. Mar 28, 2019 #1
    HomeBuilt101
    HomeBuilt101
    HomeBuilt101
    Oct 20, 2015
    252
    15
    Aguila AZ
    Greetings,
    I have a hatch that I cannot seem to get sealed up for water leaks. It is on a flat surface so I want to seal it up with some kind of clear tape.
    Naturally I want some kind of clear tape that would not be an obvious eye sore on the nose of the airplane and I also want it to be removable without taking the paint off but I don't want it so easily removable that it will peel off in flight.
    Does anybody have any suggestions for a product like this? THANKS!!!
  2. Mar 28, 2019 #2
    3,606
    1,027
    No but simple window puddy under might work, except for your location in which case silicon under with tape between until it hardened
  3. Mar 29, 2019 #3
    5,821
    4,664
    You need to look into 3M "Blenderm" surgical tape. This tape is absolutely waterproof, very thin, and very very "stretchy" to go around curves. It is a surgical tape you have to get from a medical supply store. I reocmmend the 1 inch wide, but for small hatches witth little or no gap the 1/2" tape will work. I have used this tape extensively with very good results. Lasts a long time, very peel resistant. Clean the surface with alcohol, dry, and apply the tape. "Goo Gone" or "Goof Off" will remove the residue later if needed.
    proppastie likes this.
  4. Mar 29, 2019 #4
    fmartin_gila
    fmartin_gila
    fmartin_gila
    Sep 15, 2013
    69
    10
    Mandurriao, Iloilo City, Philippines
    You might look at 'sail tape' used for quick repairs of torn or damaged sailboat sails.
    Fred
  5. Mar 29, 2019 #5
    don january
    don january
    don january
    Feb 11, 2015
    2,598
    1,005
    Midwest
    I have good luck with VentureTape- Cold weather formula the down side is it is double side adhesive but if your area is white you can leave the backing on.Biggest problem with about any tape is the lose of paint.
  6. Mar 29, 2019 #6
    radfordc
    radfordc
    radfordc
    Feb 5, 2008
    1,172
    443
  7. Mar 29, 2019 #7
    HomeBuilt101
    HomeBuilt101
    HomeBuilt101
    Oct 20, 2015
    252
    15
    Aguila AZ
    Thanks everyone! I knew I came to the right place for advice
