Decided to switch my plane from lead acid to lithium, I should loose about 4 pounds of weight.
http://www.shoraipower.com/t-faq.aspx
OahuPilot, could we get some specifics? Which of the batteries this company sells did you buy? What is the setup of your plane again that draws on your battery? What alternater do you have to charge? (auto/revmaster/aerovee). Thanks it will help make a better file page for the "to do list" file.oahupilot said:skip,
Got the battery and installed it, it works. Not a whole lot else to comment on really. you don't need a special charger or anything funky the battery will charge from the alternator just fine
Enter your email address to join:
