Guys,
My friend and long-time fellow RV builder/pilot "DR" R&R'd his Odyssey PC680 in lieu of an Earth X in his RV6 last year. It lasted 2 months before he switched back. His reasons were numerous, but starting
or the lack thereof on numerous occasions was a deal breaker. This by no means rules them out for me, I just have had excellent service from my
Odyssey batteries in both my RV's, my Lawnmower and my Toyota Tacoma.
That said, I purchased one of the first
PC680's off the Odyssey factory line for my RV4 back in 2001. That battery is still going strong with the new owner after 1000 hours.
Not knowing much about AGM technology, I called Odyssey customer service back then as to the care and feeding of their new battery.
As Kenny mentioned, One of the big no-no's for AGM and Lithium batteries is charging. AGM and Lithium batteries don't accept a charge anything like a dry or wet cell battery. Trickle charging (2 Amps) is the only method that won't damage an AGM battery. Odyssey specific "smart" chargers are out there but they simply bring the battery up to max charge then shut themselves off and on accordingly and are expensive. You can do the exact same thing by following the charge tables on the Odyssey website and shutting off the charger yourself. I would bet that anyone who has had problems with an Odyssey battery didn't read the charge/care tables. Another key item is temperature. The tables show that long term storage can be up to 2 years at 77 degrees F or longer at lower temps. I deployed to Iraq twice while the Odyssey 680 was in my RV4 and after 4 months each time she started right up. If it showed less that 12V I would trickle charge it up to 12.4 and stop, per the tables.
Properly cared for, an Odyssey AGM battery is what I believe the best solution for a 12V lightweight aircraft electrical system. I have one in my current RV6X that after 6 years is also going strong.
http://www.odysseybattery.com/documents/US-ODY-TM-002_1214.pdf
However comma, in 994SP's lightweight (non-starter) Diehl Case 12V system I installed a
UB12801 made right right down the road from me in Lewisville, TX. It's amp hour draw, weight, cost and robust record spoke for itself. It will even start my 35HP Kawasaki powered Hustler Raptor Zero-turn mower. They also make AGM batteries very competitive (Amazon) to the Odyssey.
http://www.upgi.com/media/2965/sealed-lead-acid-batteries-317.pdf
V/R
Smokey
