4.3 V6 Chevy information
Discussion in 'Chevy' started by ekimneirbo, Sep 16, 2008.
  1. Sep 16, 2008 #1
    For anyone considering a 4.3 V6 Chevy engine to use in their airplane, try to get a copy of a book called "Chevrolet Power" by Rich Voegelin. It was published by HP Books in 1983. Although the engine was produced long after that, this book has a wealth of technical info,dimensions,and details on the 4.3 and other Chevy engines. It has the kind of info that is difficult to find.
    Its currently available thru Amazon for less than $25.
  2. Oct 6, 2009 #2
    Grafente23
    Grafente23
    Grafente23
    Sep 22, 2009
    3
    0
    Las Vegas, NV. U.S.A.
    If you e mail us direct beltedair@aol.com we will e mail you the rebuilding information on the 4.3
    Jess
  3. May 29, 2011 #3
    flysouth
    flysouth
    flysouth
    May 28, 2011
    6
    0
    Randburg,South Africa
  4. Jan 14, 2012 #4
    slociviccoupe
    slociviccoupe
    slociviccoupe
    Apr 1, 2011
    184
    0
    Palm Bay Fl.
    also look at mercruiser's line of chevy v6 engines. most come fuel injected. the injection system and engine specs for bearing clearances ect could be applied to making the all aluminum v6 into continuous duty use. they spin 5.5k-6k rpms all day in boats and put out as much power as a small block v8 but with less tq.
    and most are vortech motors. aluminum efi intake manifolds are standard.
    not saying to use the irpon block mercruiser engines but their internals and specs they are built with would be good for aircraft power in an all aluminum package.
  5. Jan 16, 2012 #5
    Streffpilot
    Streffpilot
    Streffpilot
    Jul 13, 2011
    318
    170
    Mukwonago, WI
    how much power can reliably be pushed through one of these 4.3's at about 3200 rpm max???
  6. Jan 16, 2012 #6
    stol
    stol
    stol
    Feb 15, 2008
    497
    145
    Jackson Hole Wyoming
    xxxx
  7. Jan 17, 2012 #7
    GrizzlyV6
    GrizzlyV6
    GrizzlyV6
    Jan 15, 2012
    135
    4
    Lee's Summit, MO
    Hey Ben, hope you're doing well.
    I talked to Craig Catto about cutting my prop. The power range we're working with is 3500rpm for take off @195hp and 3000-3200rpm for cruise @ 175-185hp.
    I will play with scanner and see if I can get the document to save to my computer and post it as a link here. Is that possible on this site?
    Jim
  8. Jan 17, 2012 #8
    stol
    stol
    stol
    Feb 15, 2008
    497
    145
    xxxx
  9. Jan 17, 2012 #9
    GrizzlyV6
    GrizzlyV6
    GrizzlyV6
    Jan 15, 2012
    135
    4
    Lee's Summit, MO
    You have quite an airplane/toy there. I know I was impressed with the take off.
    For the masses, here's a short story. My family and I stopped in Jackson Wyoming on the continuation of our vacation after leaving Yellowstone. Ben met us at his hangar and gave me a walk around then the big moment. Let's go for a ride. When we got to the hold short line, Ben got his clearance for departure. From idle to wheels off the pavement happened in about 75 feet or so. It was very short and quick.
    Let us know what show and when. It's always fun to watch people you know in the spotlight.
    Jim
  10. Jan 20, 2012 #10
    Irelands_Son
    Irelands_Son
    Irelands_Son
    Jan 20, 2012
    3
    0
    St.Catharines
    Im a licensed Mechanic and would be happy to answer any questions you have regarding this or any other engine. If I dont reply here then please email me.
  11. May 5, 2012 #11
    TXFlyGuy
    TXFlyGuy
    TXFlyGuy
    Apr 26, 2012
    1,546
    453
    Republic of Texas
    About 250hp and 300 ft lbs @ 3000 rpm.
