3D printing in the Homebuilt world.
Discussion in 'Workshop Tips and Secrets / Tools' started by FritzW, Sep 17, 2019.
  1. Sep 18, 2019 #21
    rtfm
    rtfm
    rtfm
    Jan 3, 2008
    3,181
    566
    Brisbane, Australia
    Hi. I have an Ender3 but have upgraded to a Duet3d Wifi board. Wonderful web interface, and all changes are via Goode. Very impressed with it.
  2. Sep 18, 2019 #22
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    1,125
    244
    YMM
    For wireless... Replace the microsd with one of the micro to regular sd adapters (little 6$ ribbon cord)
    Then use one of the wifi sdcards. Do a quick search most are hackable. You write one byte to the card to turn it on, then it's a NAS drive in essence. Walk to printer select file and go. No need to touch it.
  3. Sep 18, 2019 #23
    Mcmark
    Mcmark
    Mcmark
    Sep 24, 2013
    269
    126
    Owings, MD
    Can somebody explain what language Y'all are speaking? I'm just barely able to type!;)
    Topaz likes this.
  4. Sep 18, 2019 #24
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,529
    3,140
    Las Cruces, NM
    Translation: You can connect you 3D printer to you home WiFi network, it's very handy but not, at all, necessary if you just want to print stuff.
    Mcmark likes this.
  5. Sep 18, 2019 #25
    9,486
    6,241
    Mcmark likes this.
  6. Sep 19, 2019 #26
    3,701
    1,075
    differential compression test is 80 PSI
  7. Sep 19, 2019 #27
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,529
    3,140
    Las Cruces, NM
    Well... some how we got in our heads that we needed a 12mm adapter, it turns out the plug holes are 14mm and we were already setup (old age will do that to you):mad: At lest my version of the adapter only cost about 10 cents to make.
    I did pressure test it anyway (as high as I could by just putting my thumb over the hole, about 80psi which is what I set the regulator for). I was surprised how well the hose coupling worked, nice and tight, nothing leaked. I'll print a new one to see how well the threads work.
    Oh well, screwing around with stuff is half the fun.
    The metal one (made by a fellow hangar bum) is on the left.
    ScaleBirdsScott likes this.
  8. Sep 19, 2019 #28
    6,304
    2,247
    I'd never fit in with your EAA group. I'm way too alternate engineering to fit in. ;):(
    The last time I needed one of these I just beat the ceramic out of an old plug and brazed in a 1/4" pipe. I's crooked, ugly, doesn't leak and still somewhere in the bottom of the "I might need this again" tool drawer.
    Topaz, proppastie and akwrencher like this.
  9. Sep 19, 2019 #29
    3,701
    1,075
    the compression testers come with those fittings however they do get lost., and the small NGK plugs .....would be another purchase and shipping charge. Had a retired friend of mine once showed me the hinge he made for his shed.
  10. Sep 20, 2019 #30
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,529
    3,140
    Las Cruces, NM
    You just described the 3 or 4 that are laying around my garage somewhere. The problem was we thought we needed a smaller one that nobody had, or even the right plug to make one out of.
  11. Sep 20, 2019 #31
    addicted2climbing
    addicted2climbing
    addicted2climbing
    Jan 27, 2012
    942
    264
    Glendale, CA
    I once made a large 3D printed cap to to simulate an IP test. It was sealed with o-rings at its interface. What I found was that the 3D print was so porous that it leaked like a sieve. You might want to coat that adapter in CA or thin epoxy or perhaps brush on experimental airplane gas tank sealer. But then again, 3D printing has come a long way so maybe yours is not as porous.
    Let me know how it goes.
  12. Sep 20, 2019 #32
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,529
    3,140
    Las Cruces, NM
    I was concerned about that but my very unscientific -thumb over the hole at 80 psi- test didn't show a problem. If it did I was just going to coat the inside with something like Elmer's glue and pressurize it to force gunk in to the pores.
    There are so many print settings though. At least I know my current settings seem to make a pretty airtight material.
  13. Sep 20, 2019 #33
    6,304
    2,247
    That is the curse of needing a tool NOW. You end up making one. :rolleyes:
    proppastie likes this.
  14. Sep 20, 2019 #34
    gtae07
    gtae07
    gtae07
    Dec 13, 2012
    1,791
    1,061
    Georgia
    We've 3d printed vacuum boxes for doing small composite repsirs at work. At least using the makerbot, we had to print full infill and cost the box in epoxy to prevent leaks.
  15. Sep 20, 2019 #35
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    1,125
    244
    YMM
    Water and airtight aren't exactly "easy" to achieve. You certainly won't get there with stock profiles.
  16. Sep 20, 2019 #36
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,529
    3,140
    Las Cruces, NM
    It could have been leaking, it just wasn't leaking enough for me to tell in a quick and dirty "this otta work" test.
    If I was *deliberately trying to make an airtight part I'd turn the parts fan way down, increase the extruder temp and slow the print speed down. But just using the generic PETG settings seems to have worked pretty well.
  17. Sep 20, 2019 #37
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    1,125
    244
    YMM
    Water/airtight I've got a profile tweaked from a TPU profile - no retraction, inside out, slight overextrusion, minimal cooling. And yeah super hot...
    gtae07 likes this.
  18. Sep 21, 2019 #38
    Hephaestus
    Hephaestus
    Hephaestus
    Jun 25, 2014
    1,125
    244
    YMM
    Got to see the new Ender 5 Plus in person this morning.
    If you're currently shopping... Definitely worth a look. 350x350x400mm build area. So 2" bigger than the cr10s.
    There will be some neat options with this setup to come I'm sure.
  19. Sep 22, 2019 #39
    TerryM76
    TerryM76
    TerryM76
    Sep 8, 2012
    478
    173
    Tempe, AZ
    My wife has similar comments about me.....
  20. Sep 22, 2019 #40
    Bill-Higdon
    Bill-Higdon
    Bill-Higdon
    Feb 7, 2011
    435
    136
    Salem, Oregon, USA
    :rolleyes:
