Waiex versus Sonex Tail Design?
lr27
Nov 3, 2007
3,730
I watched The Bonanza arrival several years ago at OSH and every V tail had difficulty with alignment in a moderate crosswind compared to the straight tail version, so personally, I prefer the straight tail
That's probably because the v tails are too small or are at the wrong angle. I'm sure you wouldn't like a regular vertical stab that was too small. Just because my first car was a lemon doesn't mean I avoid all station wagons. Now if you're talking certified Bonanzas only, you may have a point.
Did you see any Leeon Davis designs come in?
On models, v-tails that look right are too small. A rule of thumb is that a v-tail should have the same area as conventional tail surfaces.
lr27
Nov 3, 2007
3,730
BTW, if you tell your search engine to look for Drela tail sizing, you'll find a method for quickly sizing v-tails. Probably on an aircraft with people on board, it would be worth going into more detail.
wktaylor
Sep 5, 2003
158
Midwest USA
In the 'for-what-its worth' [repeat?] category...
AC23-9 EVALUATION OF FLIGHT LOADS ON SMALL AIRPLANES WITH T, V, +, OR Y EMPENNAGE CONFIGURATIONS
NOTE.
Most of empennage configurations also benefit from discretely placed dorsal or ventral fin(s) or stabilizer leading-edge extensions/saw-steps ['dog-tooth']… and/or vortex generators.
