jamdfingr
So I ran up the engine on the weekend after having changed out the oil, checked every passage, valve, spring, filter and pipe possible. The engine started up with no issues at all with good cylinder pressure. I let it warm up for a bit and then started some higher RPM runs (with it restrained on the ground) around 3000rpm. The temps started to come up on the oil slowly with a resulting drop in pressure in the oil. The CHTs came up but remained very low throughout the testing. I let the oil come up to about 90-100 degrees C when the resulting pressure drop was down to about 10 PSI. I used a temp gun to check the oil in the cooler and it was reading the same as the gauge. The cylinder heads were all reading fairly consistently around 150 degrees C and this was the same on the gauge.
So given this test was on the ground and tethered, I expected to get a hotter engine as the cooling flow through the plenum is lower than when flying. What I did notice however was that the oil temp kept climbing and the pressure continued to drop while the CHT's remained pretty stable.
So the issue seems to be lack of oil pressure. The OEM suggests a minimum 25 PSI is required and I was getting well below that. The Oil temp seems to be in range between 50C and 120C but the amount of drop in pressure is significant. It seems that even with the recommended oil in the system, that the oil pump cannot keep up the pressure once the oil warms up. I think I will need to pull the oil pump itself and inspect the gears to see if there has been wear on them as this just doesn't seem right. If that doesn't work, then I guess the only conclusion is that the bearing clearances have opened up enough to increase oil flow and reduce pressure which will require a total strip, assess and rebuild of the engine.
This might get expensive soon... (but still better than falling out of the sky).
Thanks for the other comments and suggestions too.
