jamdfingr
All, my apologies as I thought the thread on this had gone cold until I spotted the replies today.
So, lots of good areas of investigation and I will try and identify what I found from each to rule out some of the theories.
I managed to replicate the issue on the ground. Tail tied up, engine run up to 3200rpm and held at constant throttle and mixture. As the oil temp began to rise, the manifold pressure kept coming down along with the oil pressure. The CHT's stayed in the green the whole time so I doubt the heads were overheating. Then, at some point, the engine RPM begins to drop, the Manifold pressure drops and the CHT's begin to rise quickly. I bring the engine back to idle before any further damage can occur but it seems to only happen at WOT.
So I check for lean mixture and the plugs are wet and more towards being too rich. This is also evident by some of the soot on the outside of the cowling where the exhaust flows so lean is not the issue.
I checked the fuel vent for starvation but it is clear and there was only half a tank so vaccuum in the fuel doesnt seem to be the problem. There is a gascolator which is gravity fed, but again in using the electric fuel pump gave no change so doubt it is a fueling problem.
Checked the steel inlet manifolds and no obstructions to the air intake.
The oil being used was a 10W 40 and this was changed from a 15W50 which was reccomended until 50hrs which the engine achieved hence the switch. There was sufficient oil in the sump and has been changed now.
I pulled the oil bypass valve and it came out with minimal obstruction so doubting it was the restriction.
Am waiting for a borescope to be able to check the condition of the cylinders but everything in the valve heads seems fine with no evidence of heat or burnt oil there. Even the oil that came out did not have much in the way of metal particles or burning so while it got hot, I doubt it heated the engine. (Note, sustained WOT at that point was causing rising CHT and oil temps but not past their limits).
So I am still scratching my head on this one. Am going to check condition of the jugs, have already replaced oil and will probably give it another extensive ground run to see what is going on or at least replicate the fault with a video of the gauges.
Thanks for all the suggestions so far, I have worked through most of them and agree that until I know what I have got, I am not risking my life behind an unknown defect in the engine. Will see what else I can diagnose first and then will look at pull the cylinders off for a closer inspection of the rod bearings and crank.
Cheers,
Luke.
Cheers,
Luke.
