LBarron
Questions for you designers out there:
if an airplane were to be designed with twin vertical stabilizers, is the area for each v.s. half the calculated area for a single v.s, or is there a specific ratio or altogether different formula when using two? Also, must they be at an angle to vertical or is straight up ok?
Thanks,
Leland
Thanks,
Leland
