Torpedos with Wings - race plane
delta
May 26, 2011
2,162
Brookside Utah
View attachment 31341 This makes me want to release some four letter words. Freaking outstanding! Really. Can you do me a big favor and remodel this with long, thin, swept rutan landing gear on the wingtips? The kind that the Quickie uses...just longer to clear that rear prop. View attachment 31342 It would be absolutely outstanding with rutan gear and a pair of briggs and stratton 15hp engines like the DA-11 uses: View attachment 31343
Sorry for the late response as I've been out of town and without internet for a week. Bending the tips down for the gear would make it a handful in the wind it looks like to me. This one would probably do better with an long easy type gear.
delta
May 26, 2011
2,162
Brookside Utah
Very neat, it would be nice to see that as original, without the duct but with the prop still in the back.
Here's a typical ducted fan racer shape of the future
There's a problem with a prop in the back in terms of interference with the control surfaces. If you loose the duct you'd have to go counter rotating to eliminate a potentially deadly situation. This guy kind of excites me. It's like a para suit on steroids. It'd be a wild ride with my mz202 on the nose, but potentially fast and fun.
Starman
May 16, 2009
2,011
High in the Andes Mountains
I found a sketch of the supersonic fan I made. 42" dia. and for 5000 RPM.
Blades were 16 ga stainless steel with a back up doubler on the root of 14 ga stainless, fuse welded to each other around the outer edges only. Before fusing, the blades were rolled to get the airfoil shape and provide the twist at the same time. The outer leading edges were sharpened with a grinder.
Blades were attached with rivets to a piece of 1/4" stainless bent into an angle, and these angles were bolted to an 18" diameter hub that was made from a single piece of 3/4" thick solid T1 high strength steel.
The straight lines on the end view of the blades arent' really there, they are just to show how the rolling also provides the blade twist.
Sockmonkey
Apr 24, 2014
1,876
Flint, Mi, USA
You might want to invert the rudder to serve as the holder for the rear gear in a tail-drager setup so it can act as a prop guard. The mains, I'd make them retractable because they will also need to be rather long. The big sticking point for push-pull setups has always been the need to keep both ends well clear of the ground.
Speedboat100
Nov 8, 2018
1,059
Europe
