Thinnest plywood available
11,103
How big a sheet? Hobby shops sell 1/64" plywood; I think I got it in 2' x 4' sheets some years ago.
-Dana
Always keep clothes and weapons where you can find them in the dark.
wally
Mar 31, 2004
932
southwest TN.
Wicks Aircraft has various kinds of plywood.
They have it in 4' by 4' sheets and I am pretty sure they will cut it for shipping to whatever size you need. They have it down to 0.8 mm thick.
Wally
topspeed100
Banned
May 4, 2009
4,063
Oulu/Finland
This may be strange, but does anyone know where I can get 1mm (approx) sheets ofNON aircraft plywood? Ron
All plywood that is not stamped as aviation quality are non aviation...1 mm is available...for aviation use I would not use 2nd grade plywood ( it has branch wood marks on it ) since it is weaker.
0,4 mm is the thinnest !
delta
May 26, 2011
2,826
Brookside Utah
Quite a few years back I found some 3'x6' sheets of 3/16" at Home Depot. I believe they were skins for making hollow doors. I've made quite a few RC with them by ripping them into 1" strips.
Rick
solynubes
May 21, 2011
93
salvatierra, Spain
Hello rheuschele
I am working with a plywood factory to manufacture thin plywood okume reasonable price and quality.
Can you wait a little? I hope to have some results soon. I will use this plywood for my own plane if the result is good. You can contact me by private [email protected]
saludos
solynubes
May 21, 2011
93
salvatierra, Spain
Hello Ron
In a few days will have a first test result.
Measures more or less the plywood will be: 1.5 mm thick
1200mmx2500mm. Is the size of the press makes.
What size you need?, How many pieces?
saludos
topspeed100
Banned
May 4, 2009
4,063
Oulu/Finland
I measured the 0,4 mm plywood I have on my scale and it indicates 4 gr for 100 cm2.....and plywood is generally indicated ar 640-700 kg /m3 which would yield 256-280 grams for m2..the 0,4 mm may have more glue and there is no way I can brake it by pulling that 10 cm x 10 cm piece apart with my hands. This may be too strong stuff for the wing covering if lightness is the goal?
solynubes
May 21, 2011
93
salvatierra, Spain
Hello rheuschele
How many sheets of plywood you need?
2500x1220mm thickness 1,5mm 2mm 2,5mm 3mm
I can consult the price with the shipping carrier for your area. Chicago city?.
