SOLO Aircraft Engines
homebuilderfan
Feb 22, 2015
110
Italy
http://aircraft.solo-online.com/index.php
Some time ago I put a comment about Solo Aircraft Engines I had just found out.
I was interested to put these engines on ultralight aircrafts (european ultralight).
These Solo engines are NOT related to the "old" two stroke single cilynder Solo that you could find on paragliders or similar. We are talking about certified engines. Ok, I agree that an engine used on a motorglider maybe doesn't have the stringent requirements an engine put on a conventional plane has (because of the fact that its use is not continuous and "hard" the same way); but anyway it doesn't look to be a lawnmower class engine arranged to fit in an aircraft!
Well, now I have had some contact with the company and I post here the result.
WYSIWYG: that is: you get the items you see on the website. Stop. You can't get a reduction gear out of those you see listed.
Is it a problem? Sure it is, for me. I can't think to design and build a reduction gear! Or an exaust system.
Is there a solution? Yes; if you are going to pay for the development and building of the missing part.
Unfortunately not for me. I am only an amateur pilot.
But maybe this is interesting for someone else.
Bye.
dino
Sep 18, 2007
680
florida
Just copy the the belt reduction as used in the motorgliders using a shorter belt and pylon. The Picollo drive as is would be nice. It even has a folding propellor.
Armilite
Sep 5, 2011
3,378
AMES, IA USA
Bye.
CC?
HP@Rpms?
Weight?
TBO?
COST?
5,345
CC?
HP@Rpms?
Weight?
TBO?
COST?
Did you click on the link in the article you quoted? Lots of info there. You can even see pictures. No price info at the site, but these are small engines of about 23 to 68 HP.
They are marketed for use in sophisticated (i.e. expensive) European motorgliders, so my >guess< is that they are not cheap.
homebuilderfan
Feb 22, 2015
110
Italy
Ayou are right. They are not cheap. Anyway you have also to consider the whole thing.
But, as I said, useless for me...
Armilite
Sep 5, 2011
3,378
AMES, IA USA
I did click on link but didn't have time to really go through it. Yes, any Company that doesn't put their PRICE's on there web page are probably going to be High. What HP do you really need or want? I only heard of the old SOLO 210 Single.
SOLO Engines for Comparison. Now put some PRICES and their TBO Times to them and we will now more. Notice they recomend 100LL in all of their 2 Strokes!!!
2350
Description of construction
- In-line-two-cylinder-two-stroke engine
- Air-cooling
- mixture control via
- two diaphragm carburetors
- CDI ignition
- Crankshaft mounted propeller
- No engine starter
- Crank-case-pressure operated fuel pump
Download of technical drawing as pdf-file here.
Technical Data
Engine Displacement 430 ccm, cyl. bore 70 mm, stroke 56 mm
Compression rartio 10 : 1
Ignition unit Magneto SOLO, ignition coil Ducati
Ignition plugs BOSCH W 5 AC heat range 225 or Champion L82 C, Gap 0,5 mm
Thread M 14X1,25 mm. In combination with spark-plug-cap
(23 00 701, R=5kOhm)
Carburetor SOLO, metering-device WALBRO
Fuel pump Bing
Direction of rotation Counterclockwise, seen in direction of flight
Fuel 2-Stroke mix, AVGAS 100LL, premium gas (min. 95 ROZ)
Mixture Mixture ratio 1 : 40 , 2-stroke Castrol mineral oil or synthetic oil, or other oils with specification according to JASO FC oder FD
Dry Weight Appropx. 16,8 kg complete with muffler, without propeller
Operational data and limitations
without muffler d=22mm
with muffler d=22mm
Cruise power 19.6 kW/26.3hp at 5,500 1/min 15.3 kW/20.5hp at 5,500 1/min
Max. rpm 6,00 1/min 6,500 1/min
Recommended rpm 5,000 1/min 5,000 1/min
Low idle rpm Not available - no throttle control Not available - no throttle control
Cylinder head temp. Max. 275°C (measured at spark plug) Max. 275°C (measured at spark plug)
Fuel consump. at cruise Approx 2,24 US gal./hr (8,5 l/h) Approx 2,24 US gal./hr (8,5 l/h)
2350 - B
- Air-cooling
- CDI ignition
- Propeller mounted on belt drive
- Electric starter
- AC generator
Technical Data
Ignition unit Magneto SOLO, ignition coil BOSCH or PVL
Carburetor WALBRO
Starter Fa. SJCE Tyep: 102 or UNITED TECHNOLOGIES Tyep: 1077-28-Mo 30 sM
Dry Weight Appropx. 26 kg
Belt drive Ratio 1:2,1
Take-off-speed, power and Max. cont. speed, power 17 kW (23 HP) at 6,300 1/min.
Max. rpm 6,500 1/min.
Recommended rpm 5,500 1/min.
Idle rpm 2,000 1/min.
Fuel consumption Max. speed approx. 2.25 US gal./hr. (8.5 l/hr.)
Cruising speed approx. 2.03 US gal./hr. (7.7 l/hr.) at 5,500 1/min.
2350 - BS
- Air-cooling
- one float type carburetor
- CDI ignition
- Electric engine starter
- AC generator 12 V, 180 W
Technical Data
Carburetor BING
Take-off-speed, power and Max. cont. speed, power 17 kW (23 HP) at 5,500 1/min.
Max. rpm 5,500 1/min.
Recommended rpm 5;300 1/min.
Fuel consumption Max. speed approx 2.38 US gal./hr. (9.0 l/hr.)
Cruising speed approx. 1.85 US gal./hr. (7,0 l/hr.) at 5,300 1/min.
2350 - C
- Air-cooling
- mixture control
- two diaphragm carburetors with additional fuel pump
- CDI ignition
- Electric engine starter 12 V, 400 W
Technical data
Compression rartio 12 : 1
Carburetor MIKUNI BN 38
Starter Fa. SJCE Tyep: 101
Dry Weight Appropx. 25 kg
Belt drive Ratio 1:2,3
Take-off-speed, power 22 kW (30 HP) at 6,500 1/min.
Max. cont. speed, power 20 kW (27 HP) at 6,100 1/min.
Recommended rpm 6,500 1/min.
Idle rpm 3,000 1/min.
Fuel consumption 100% cont. speed approx 3.96 US gal./hr. (15.0 l/hr.)
75% cont. speed approx. 3.7 US gal./hr. (14.0 l/hr.)
2350 - D
- Air-cooling
- mixture control via two diaphragm carburetors
- CDI ignition
- No engine starter
Technical Data
Ignition unit Magneto SOLO, ignition coil DUCATI
Ignition plugs BOSCH W 5 AC or Champion L82 C, Gap 0,5 mm. Thread M 14X1,25 mm. In combination with sparkplug-cap (23 00 701, R=5kOhm)
Carburetor Solo, metering-device WALBRO
Fuel pump BING
Dry Weight Approx. 23,5 kg, complete with muffler, without propeller
Belt drive Ratio 1 : 1,56
Take-off-speed, power and Max. cont. speed, power 22 kW/29.5hp at 6,500 1/min.
Max. rpm 6,600 1/min.
Idle rpm Not available - no throttle control
Fuel consumption at cruise Approx 3.7 US gal./hr (14 l/hr.)
2489
General engine description
- Twin - cylinder in line - two - stroke - engine
- Liquid cooling with belt driven waterpump
- Lubrication by fuel-oil-mixture
- Two float carburetors with additional fuel pump
- Electronic high-voltage ignition
- Intake control with reed valve into the crankcase
- Crankshaft layout for belt transmission
- Electric starter 12 V, 400 W
- AC generator
Technical data
Engine Displacement 430 ccm, cyl. bore 72 mm, stroke 60 mm
Ignition unit Electronic high-voltage ignition (Selettra)
Ignition plugs WSR 6 F
Carburetor BING carburetor type 54
Direction of rotation Clockwise, seen in direction of flight
Dry Weight Approx. 30.0 kg
Generator 12 V, 70 W
Take-off-speed, power 30 kW (40 HP) at 5,900 1/min.
Max. cont. speed, power 30 kW (40 HP) at 5,900 1/min.
Idle rpm 2,300 1/min.
Max. temp. cooling liquid 115 °C (240°F) measured in the cylinder - head
Fuel consumption Max. continous power approx. 4.49 US gal./hr. (17 l/hr.)
75% continuous power approx 3.17 US gal/hr. (12 l/hr.)
2625 - 01
- Lquid cooling
- One diaphragm carburetor
- Dual electronic high-voltage ignition
- Electric starter
- AC generator
Technical data
Engine Displacement 625 ccm, cyl. bore 76 mm, stroke 69 mm
Compression rartio 9.5 : 1
Ignition unit Dual electronic high-voltage ignition (Ducati Energia) or ISKRA
Ignition plugs BOSCH W5 AC Gap at electrodes 0.5 mm
Carburetor MIKUNI diaphragm carburetor Typ BN 38
Mixture Mixture ratio 1 : 50 , 2-stroke Castrol mineral oil or synthetic oil, or other oils with specification according to JASO FC oder FD
Dry Weight Approx. 23.0 kg
Generator 12 V 150 W Ducati, 12 V 70 W
Take-off-speed, power 5,900 1/min. with a power of 39 kW (53 HP)
Max. cont. speed, power 6,250 1/min. with a power of 39 kW (53 HP)
Max. rpm 7,000 1/min
Idle rpm approx. 2.300 1/min
Fuel consumption Max. continous power approx. 5.94 US gal./hr. (22,5 l/hr.)
2605 - 02
- Lquid cooling
- Two diaphragm carburetors
- Electric starter
- AC generator
Technical data
Dry Weight Approx. 24.0 kg
Take-off-speed, power 6,500 1/min. with a power of 47 kW (64 HP)
Max. cont. speed, power 6,500 1/min. with a power of 47 kW (64 HP)
Idle rpm approx. 2,300 1/min
Fuel consumption Max. continous power approx. 6.47 US gal./hr. (24.5 l/hr.)
2605 - 02 i
- Liquid cooling
- Electronic fuel injection
- Redundancy system
- AC generator
Technical data
Ignition unit Electronic, two butterfly shutters, mapped
Fuel injection Electronic, two butterfly shutters, mapped
Dry Weight approx. 24 kg without exhaust (according to airframe manufacturer)
Generator 12 V 500 W
Coolant Engine coolant (Glysantin BASF G48), tab water (0-20°dh) in a
mixture of 40:60 (27°C)
Take-off-speed, power 6,600 1/min. at a power of 50 kW (68 HP)
Max. cont. speed, power 6,600 1/min. at a power of 50 kW (68 HP)
Max. rpm 6,700 1/min
Cut off speed by CPU 6,700 1/min.
Armilite
Sep 5, 2011
3,378
AMES, IA USA
2350
2350 - B
Mixture Mixture ratio 40:1 , 2-stroke Castrol mineral oil or synthetic oil, or other oils with specification according to JASO FC
2350 - BS
2350 - C
2350 - D
2489
2625 - 01
Mixture Mixture ratio 50:1 , 2-stroke Castrol mineral oil or synthetic oil, or other oils with specification
2605 - 02
2605 - 02 I
