Simonini Single Cylinder Engines HP
Armilite
Sep 5, 2011
3,739
AMES, IA USA
Some Data collected for Simonini Single Cylinder Engines, and you didn't think your little 185UL, and 277Ul could make more HP!
COLIBRI'
Bore : 58mm
Stroke : 52mm
Displacement : 138cc
Compression Ratio : 12.5/1
Ready to fly : 12kg
Consumption at 6500rpm : 1.4 liters/hrs
Power at 8400rpm : 20hp
Static thrust : Over 65kg
REDUCTION RATIO AVAILABLE: 1:314 - 1:307 - 1:3
SIMONINI 140
Bore : 58 mm
Stroke : 52 mm
Displacement : 138 cc
Compression Ratio : 12,5/1
Ready to fly : 11kg
Consumption at 6500rpm : 2,5 liters/hrs
Static thrust : Over 60kg
REDUCTION RATIO AVAILABLE: 1:314 - 1:307 - 1:3 - 1:293
$3,212.00
Mini 4, Single Cylinder Engine Specs:
Displacement (cm³)164cc
Bore (62mm)
Stroke (54.5mm)
Compression Ratio = 11:1cr
Power = 24hp - 16.18kw
RPM = 7,200
Weight of the engine with:
exhaust, air filter, propeller: = 9 Kg / 20 Lbs
Reductions Available:
$3,621.00
Mini 2 Plus, Single Cylinder, Engine Specs:
Displacement (cm³)202cc
Bore (66.4mm)
Stroke (58mm)
Compression Ratio = 10.5/1
Power 26hp - 19kw
RPM = 7,200
exhaust, air filter, propeller: 13 Kg / 29 Lbs
Reductions Available: 1:2.26, 1:2.3, 1:2.34, 1:2.42, 1:3
Power and Torque
RPM HP kW Kgm
3,000 9 6.62 2.15
3,500 11.2 8.24 2.29
4,000 12.8 9.42 2.29
4,500 14.4 10.6 2.29
5,000 16.5 12.14 2.36
5,500 18.7 13.76 2.36
6,000 21 15.46 2.51
6,500 22.7 16.74 2.51
7,000 24.5 18.03 2.51
7,500 25.5 18.77 2.43
7,800 24.9 18.33 2.29
$3,821.00
Mini 2S, Engine Specs:
Bore (66.4mm)
Stroke (58mm)
Power 26hp - 19kw
RPM = 7,200
Power and Torque
RPM HP kW Kgm
3,000 9 6.62 2.15
6,000 21 15.46 2.51
6,500 22.75 16.74 2.51
$4,290.00
Mini 2 EVO, Engine Specs:
Displacement (cm³)230.8cc
Bore (70mm)
Stroke (60mm)
Compression Ratio = 10/1
Power 33Hp - 24kw
RPM = 8,000
exhaust, air filter, propeller: 16.4 Kg / 36 Lbs
Reductions Available: 1:1.23, 1:1.234, 1:1.24
$4,144.00
Mini 3, Engine Specs:
Displacement (cm³)270cc
Bore (72.8mm)
Stroke (65mm)
Power 36hp - 23.7kw
RPM = 7,000
exhaust, air filter, propeller: 20 Kg / 44 Lbs
Reductions Available: 1:2.49, 1:2.57, 1:2.76
Power and Torque
RPM HP kW Kgm
4,500 15.3 11.26 2.43
5,000 16 11.78 2.43
5,500 24 17.66 2.72
6,000 27.4 20.17 3.29
6,500 29.9 22.01 4.08
7,000 32.2 23.7 3.29
7,500 30 22.08 2.86
$5,858.00
Victor 1, Engine Specs:
Displacement (cm³)362cc
Bore (80mm)
Stroke (72mm)
Compression Ratio = 9.5/1
Power 44hp - 32.75kw
RPM = 6,500
exhaust, air filter, propeller: 32 Kg /70 Lbs
Reductions Available: 1:2.7, 1:2.8, 1:3
Power and Torque
RPM HP kW Kgm
3,000 15 11.04 3.58
3,200 16 11.78 3.58
3,500 20 14.72 4.08
4,000 24 17.66 4.3
4,500 31 22.81 4.87
5,000 35 25.76 5.01
5,500 38.8 28.56 5.01
6,000 42 30.91 5.01
6,200 43.5 32.02 5.01
6,500 44.5 32.75 4.87
6,700 40.6 29.88 4.3
$6,185.00
Victor 1 Plus, Engine Specs:
Displacement (cm³)382cc
Bore (80mm)
Stroke (76mm)
Bing 54 36mm
Power 48hp - 35kw
RPM 6,500
RPM HP kW Kgm
3,000 15.6 11.48 3.72
3,200 17.28 12.72 3.87
3,500 20.3 14.94 4.15
4,000 25.6 18.84 4.58
4,500 31.5 23.18 5.01
5,000 36.65 26.97 5.23
5,500 41.8 30.76 5.44
6,000 45.6 33.56 5.44
6,200 47.12 34.68 5.44
6,500 47.45 34.92 5.23
6,700 45.6 33.56 4.87
VICTOR 1 SUPER, Engine Specs: <----Sets the Bar on Singles!
Displacement (cm³)400.5cc
Bore (82mm)
Stroke (76mm)
Bing 54 38mm
Power 54hp - 40.2kw
RPM 6,500
