Problems using Motorcycle motor?
Typhoon
Apr 21, 2011
31
Germany
Hi,
I'm not a motor expert and I really wonder when I see the next website (down). It's realiable to use motorcycle motor in airplane? (not about if the rpm are good or not, otherwise with temperature and maintain the 70% power 3 hours or negative G's problem, for example).
"Motorcycle engines, though very high tech these days and capable of putting out huge horsepower, are not designed to operate like airplane engines. Airplanes can fly for hours on end at a steady 70 percent power, motorcycles usually operate far below that level with occasional bursts of high revs. Motorcycle engines have power but they're not designed to deliver it the way airplanes need it, not that they can't do it and with some gearing to get the revs right, they might do it. But problems with a motorcycle means you coast to the berm and check it out, problems with a plane means you look for a place to set her down, preferably close by and smooth. It's one area where engine choice might be a bit more critical and using an engine designed for that purpose might make a lot of sense. Again, homebuilders do a lot of great work and they may have just the right combination of skills to use something from a motorcycle and make it work reliably."
source: Motorcycle Engine Powered Airplanes
Thank you!
Typhoon
