Pocket altimeter in an ultralight?
Discussion in 'Instruments / Avionics / Electrical System' started by cluttonfred, Mar 23, 2018.
  1. Mar 23, 2018 #1
    6,353
    2,224
    Has anyone ever used a pocket hiking altimeter like this in a light aircraft? Could it make a useful lightweight alternative for an ultralight panel or is there some reason (response time, accuracy, etc.) that it wouldn't be worth it?
    https://suncompany.net/tactical/altimeters/
    MadRocketScientist likes this.
  2. Mar 24, 2018 #2
    Apr 4, 2007
    8,548
    2,963
    I used a Suunto wrist altimeter for paragliding.
  3. Mar 26, 2018 #3
    slevair
    slevair
    slevair
    Oct 7, 2010
    110
    41
    (6TN5) Pulaski, TN / USA
    I have used a wrist altimeter from back in my skydiving days. It gave me no problems in ultralight use.
  4. Mar 26, 2018 #4
    Chris In Marshfield
    Chris In Marshfield
    Chris In Marshfield
    Jan 29, 2008
    1,203
    996
    Germantown, WI USA
    A lot of the newer smart phones have baro sensors in them as well. If you have a late-model smart phone so equipped, then, as they say, “there’s an app for that”.
  5. Mar 26, 2018 #5
    11,532
    3,229
    There are plenty of wrist watches with alts.
  6. Mar 26, 2018 #6
    6,353
    2,224
    In my case I am still interested in lighter and/or cheaper alternatives to ordinary panel-mounted 2-1/4” altimeters for VFR use. Some barometric adjustment is a necessary feature so I don’t think a watch would do it unless there is one with easy barometric adjustment.
  7. Mar 26, 2018 #7
    Wanttaja
    Wanttaja
    Wanttaja
    Sep 15, 2013
    1,227
    1,393
    Seattle, WA
    I once took a combination electronic altimeter, compass, and thermometer up for a test run. Biggest issue was the lack of an external static port; the altitude increased by ~200 feet just due to the prop blast during runup.
    Ron Wanttaja
    cluttonfred likes this.
  8. Mar 26, 2018 #8
    6,353
    2,224
    Ron, it's funny that you say that as I was surprised to see that the large 3-1/8" size UMA altimeters are not supposed to be connected to the static line at all. "Note: Do not connect 3 1/8” altimeter to static line, because case is not sealed and a static leak will result!" I guess that means that you would give them their own static line to a fuselage static port so as not to mess with the ASI. The smaller, more expensive 2-1/4" size UMA altimeters are sealed and do use a static line.
