"Normal" Static RPM's (New Pilots Read Before Flight!)
Aircraft: Sonerai II LTS
Fly with passengers: Maybe
Gross weight: 1150 lbs (on paper)
Engine: Revmaster 2074cc 78x92
Carb: Revflow 34mm
Prop: Ed Sterba 54x46
Prop alterations: None
Static RPM: 3350
Aircraft: 2L
Fly with passengers: Yes, light ones!
Gross Weight: 1050
Engine: Blueprinted GP1835cc, 92mm x 69mm
Carb:Zenith
Prop Manufacture: Props Inc
Prop dimensions: 54x42
Prop alterations from stock: None
Static RPM: 2900
Empty weight 555
500FPM climb at GW 2950RPM/33"
150MPH at 3200 WOT
*These numbers definitely reflect a "cruise propeller" but is very smooth, efficient and fast on less fuel. Considering purchase of a 50X42 for testing
V/R
RR
The above was 994SP with Smokey's old Props Inc. Prop. Below is the new numbers with new Sterba prop and new owner.
Aircraft: 2L
Fly with PAX: not yet
Max Gross Weight: 950
Engine: Custom (Mostly GPAS) 1835 (92mmX69mm)
Carb: Zenith
Prop Manufacturer: Ed Sterba
Prop Dimensions: 52X42
Prop Alterations: None
Static RPM: 3100
Empty Weight: 557
Takeoff Rate of Climb: ~650fpm @ 3,140rpm/33 inHg
Max Level Cruise 140mph @ 893lbs GW
Here's an interesting article from EAA that is relevant: https://www.eaa.org/eaa/aircraft-bu...nd-spinners/the-fixed-pitch-propeller-dilemma
Aircraft: 2LS
Fly with PAS: not yet
Max Gross Weight: 1150
Engine: Custom 2180 82x92 compression 7.4
Carb: Aero-Inj
Prop Dimensions: 54x47
Static RPM: 3000 28 inHg
Empty Weight: 620
Takeoff Rate of Climb: ~750fpm @ 3,000rpm/28 inHg. 2000 Alt
I think it would be helpful to have compression ratios and manifold pressure numbers included in the data. Does any one know how much an increase in compression would affect rpm?
Just to update my own numbers:
Gross weight: 1050 lbs (adjusted for engine smaller than 2180cc)
Engine: Revmaster 2074cc, 78x92, CR 8.5:1
Carb: Revflow 34mm
Static RPM: 3350 at 5,045'MSL airport elevation
