Modern version of TPG - Or the search for "Black Wood"
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by BBerson, Nov 27, 2019.
  1. Dec 4, 2019 #221
    4,240
    1,973
    Look at prices for both of these things, you'll have your answer. Nyet.
    The string for the ribs doesn't have to be strong, it just needs to hold the CF up while it cured. In fact, weak might be better as we'll eventually need to cut across it.
  2. Dec 4, 2019 #222
    Super Moderator Staff Member
    Jul 30, 2005
    13,963
    5,576
    Give me a bazillion bucks, and I'll be happy to try them out for you. :)
    Part of the "problem" here is that we already have perfectly adequate and reasonably priced methods of building airplanes. Searching for something better is fine, but it would have to meet all the requirements of homebuilding, including those that the existing materials meet. Including cost. I'm absolutely sure it's possible to come up with "something better" by some absolute engineering metric. But if nobody can afford to work in that material or method in their garage, with home tools, it rather misses the point.
  3. Dec 5, 2019 #223
    Volzalum
    Volzalum
    Volzalum
    Nov 22, 2019
    8
    3
  4. Dec 5, 2019 #224
    Jul 30, 2005
    13,963
    5,576
    You can make your own epoxy if you have the chemicals. Or your own carbon fiber, with a lot more work.
    Do you really think you can make aerogel with consistent-enough mechanical properties with this kind of rig to be useful as a structural material? Or even use any aerogel as a structural core in an aerospace-grade structure? My understanding is that the stuff, despite looking like "solid smoke", is rather brittle. That makes for a bad sandwich core.
    It has to be more than "light". It has to have all the right properties.
    pictsidhe likes this.
  5. Dec 7, 2019 #225
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    373
    96
    Lt
    blane.c likes this.
  6. Dec 8, 2019 #226
    12,461
    2,515
    I like that.
    I need to know the polystyrene face sheet thickness and total sandwich weight per square foot?
  7. Dec 8, 2019 #227
    4,240
    1,973
    The tech info PDF at their site says the 5mm thick version weighs 1kg per sq meter (0.20 lb per sq ft), the 10mm thick version weighs 1.9 kg per sq meter.
  8. Dec 8, 2019 #228
    12,461
    2,515
    .20 lb per sq ft is almost the same as .23 for aircraft aluminum (.016")
    So not light enough to interest me. Thanks.
  9. Dec 8, 2019 #229
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    373
    96
    Lt
    Added photo from pdf :
    [​IMG]
  10. Dec 8, 2019 #230
    sming
    sming
    sming
    Apr 10, 2019
    23
    10
    Thats about 200kg/m3 right? 3 times heavier than usual airex foam... perhaps the combination of high/low density still gives you some interesting edge?
    Remind me of "foam board" used by rc guys nowadays, that would be a fun construction process! Build giant rc plane with knife and glue, then glass inside/outside, done :)
  11. Dec 8, 2019 #231
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,660
    4,055
    Australian
  12. Dec 8, 2019 #232
    sming
    sming
    sming
    Apr 10, 2019
    23
    10
  13. Dec 8, 2019 #233
    7,194
    2,050
    When synthetic spider silk becomes available, things will change. It does have a low modulus, though
  14. Dec 8, 2019 #234
    7,194
    2,050
    Hmmm, silk might make a good facing for coroplast.
  15. Jan 6, 2020 #235
    lr27
    lr27
    lr27
    Nov 3, 2007
    3,292
    480
    Just to be annoying, I'll point out that, in the actual Strojnik method, the sheet can't sag because it's over a solid form, not ribs. The sheet is applied to the ribs after the bend is set.
    I've sometimes thought that a good variation would be to make a female mold over the male plug. Then drape heavy polyethylene and the sheet over a fat dowel (handrail?) and bag it into the female mold. Then you could use a thin core with it.
